Old 01-18-2010, 09:36 AM
2_Dang_Fast's Avatar
Neutral
Default Want to replace tank with a fuel cell
The CCX that I bought the other day needs some odds and ends and one of the first things on the list is that it currently has a tank from a Camaro in it. It has an external fuel pump that seems fine but the fuel gauge isn't working and was told there was an incompatibility between the sensor and the Smith gauge. I'm thinking I might as well just get a fuel cell for it. Can I just get one of these fuel cells off fleabay or is that gonna put me towards a world of hurt? Oh, don't really want to spend $1K on an Aeromotive though they seem like a choice product.
http://cgi.ebay.com/ebaymotors/Racer...ht_1157wt_1167
Old 01-18-2010, 10:00 AM
Why dont you see if you can get a guage that will read the Camaro tank or at least send your Smiths guage to Classis Inst. and have them fix it to read the GM sending unit.That would be less expensive than converting to a cell and still have your guage not work.......unless you just want a cell.........
Old 01-18-2010, 10:27 AM
Partially it's that I wanted a cell. I think I'd be better off in the long run going fresh and having a sending unit the Smith can read then pulling the gauge and having it tweaked for a GM.
Anybody deal with the cells from Summit Racing?
Old 01-18-2010, 10:44 AM
Got the Bug's Avatar
Some will say that they've never had to replace the bladder in their fuel cells, but in the racing world, 5 to 7 years is the recommended life of the bladder.
People may go longer, but they won't last forever.
http://www.atlinc.com/faqs_racing.html
"Q How long does a fuel cell bladder last?
A Most ATL racing cells are warranteed for 5 years, which is the legal life span established by most racing organizations.
Q Does FIA allow for recertification?
A Yes, under FIA rules, an approved bladder* may be returned, in its 5th year, to its manufacturer for inspection, and if warranted, up to 2 years of life extension will be granted."
Doug
Old 01-18-2010, 11:04 AM
You can get some cells with a sending unit built into them.....
Does Smiths have a "universal"sending unit for your guage?????
Old 01-18-2010, 11:35 AM
That tank doesn't use a bladder. It just uses foam instead of baffles.
Call Nisonger for what the ohm range is for their early Smith gauges used in the CCX cars. Since that tank won't accept a swing arm, you'll have to use a tube-type sender if the current one isn't correct.
You realize that that tank (cheap!!!) is 10" deep?
Old 01-18-2010, 11:39 AM
Not sure but I see I can a universal unit from a few different sources including Summit / AutoMeter
Old 01-18-2010, 12:58 PM
Those may have a different OHM reading than what your guage needs.......
changeing to a cell sure sounds like a lot of work.........but thats what makes it fun....
Old 01-18-2010, 01:38 PM
I took it one step sideways or forward or whatever and called the guys that put out Smith gauges, unfortunately the man to talk to wasn't in today so tomorrow I'll have better direction on this.
Old 01-18-2010, 02:33 PM
Cobra Make, Engine: SPF #1019
I'm happy with my Fuelsafe fuel cell - and it works with my Smiths Fuel Gauge.
