Old 04-08-2010, 08:07 AM
Default Please check my wiring....thanks
Just checking to see if this is correct. Let m eknow if you guys see anything wrong.
I forgot to draw in the Remote selonoid and the voltage regulator casings are grounded to the block along with the MSD.
Thanks
Old 04-08-2010, 11:01 AM
Anyone out there?
Old 04-08-2010, 11:09 AM
PANAVIA's Avatar
D -- Greetings, some notes ;
1. There should not be a wire between the Dist and the coils --
2. In an MSD setup the only wires attached the coil leads should be from the MSD.
3. The TACH lead in the MSD should be grey I thought.
4. I cannot see the detail of where and how your *A* terminal is wired from the VR to the rest of the system.
5. the *I* terminal on the starter solenoid can be used to feed things as it is just a "Lug" for 18-22 gauge wire.
you can have an ignition relay feed the I terminal and use it to feed things like electric chokes, MSD switched on leads, or >?
a larger drawing with the relays and their connections outlined would be helpful!
hope this helps.
Steve
Old 04-08-2010, 11:22 AM
Steve
That is the Plug wire that I am showing.
Old 04-08-2010, 10:57 PM
PANAVIA's Avatar
ahhhh -- didnt see that detail.
Old 04-09-2010, 03:29 AM
I am getting a few post about the ALT wire needing to be on the other post of the kill switch. They are saying that it needs to be on the battery feed side.
