04-18-2010, 10:06 PM
1330 or 1350 Pinion Yoke?
Hey all
I need to replace the flat pinion flange on my 8.8" diff with something a little smaller. It has the large flange and clearence against the driveshaft tunnel is very tight. Anyway, now is the time to decide which one. Thoughts?
Alba gu brąth
04-19-2010, 02:42 AM
KY
It's cliche' to say, but the system is only as strong as the weakest weak. What size is your slip yoke?
04-19-2010, 06:10 AM
Hey Larry if it clears it clears. It's not going anywhere with an independent so keep the biggest you can in there.
04-19-2010, 08:13 AM
Thanks guys!
That's kind of my thoughts too Nick. I need to find out how wide a 1350 yoke is. It can't be bigger than the flat flange currently bolted on or I'm sunk.
Brent, I haven't bought the slip yoke yet so I'll make the whole thing match the pinion yoke.
Alba gu brąth
04-19-2010, 09:03 AM
KY
Ok, thought you were matching to an existing driveshaft. In that case, go big.
04-19-2010, 12:51 PM
Larry,
Go to the bottom of this page : http://www.therangerstation.com/Maga...08/ujoints.htm
It looks like the 1330 and 1350 are the same width except for the cap diameter. I'd pick the larger cap diameter if there is a choice.
If the yoke fits.....
Tom
04-19-2010, 04:09 PM
Hey thanks Tom. That's some great info.
Both are 3.625" wide, with the 1350 having a cap diameter of 1.188" vs the 1330's cap diameter of 1.062". That's exactly what I needed to know.
One more question; when I install the new yoke, do I need to check the lash or will it still be the same as with the flat flange?
Alba gu brąth
04-19-2010, 07:13 PM
If you change the pinion flange you need to get the specs and see if it's a crush collar or shimmed pinion. They are typically done up till the torque required to turn them over is to the spec of ? inch/lbs. If you need an inch/lb torque wrench let me know.
04-19-2010, 11:36 PM
Thanks Nick! I have an inch/lb torque wrench, so I'll do some reasearch and see what I can find for specs.
Alba gu brąth
