Old 05-11-2010, 10:48 AM
Default Thinking of Moving to a carb setup
Im thinking of moving away from the FI setup I currently have and moving to a carb set up. Im curious as to what carb and manifold you guys would recommend. I have heard good things about pro systems carbs, what else should I be looking at?
Old 05-11-2010, 11:13 AM
Need more info to make a good recommendation.
Engine specs and car use info would help greatly.
Old 05-11-2010, 11:22 AM
I might be going with a single carb myself, putting the dual fours on the back burner. I've been doing some auto crossing lately and the dual fours just are not working out due to the extreme cornering.
So what would I look for? A carb specifically designed for road racing, that is where I would start my research as to which one, which brand and go from there.
Old 05-11-2010, 12:05 PM
For a 427ci Windsor, I'd do a Victor Jr. If you're running a solid roller and turning some rpms with good heads, a Super Victor would do well.
I use Quick Fuel carbs on all my engines. Excellent carbs, no issues.
Old 05-11-2010, 12:10 PM
dcdoug's Avatar
I thought you were an authenticity guy after all the pain you went through giving up the top loader. That only leaves one manufacturer.
www.partskeeper.com
Old 05-11-2010, 12:40 PM
And if you choose the carb that Doug and I use you can tune it blindfolded, with one hand behind your back, while balancing on your left foot.
Old 05-11-2010, 12:44 PM
When I order Quick Fuel carbs for a customer's engine, I give them all the specs over the phone. They are custom built. They usually don't require much tuning at all.
Old 05-11-2010, 12:45 PM
427 stroker with aluminum dart block and aluminum aft 205's. I cant remember the cam specs, 10.5 compression. Looking for hard street driving. My main issue is that im running megasquirt FI program and I cant find anyone in my area to tune it. I just had it re built and it is makeing a very loud pop from the pipes when I let off the gas after moderate acceleration. I could go with another FI program but would rather just simplify. If anyone is lokking for a FI set set up to run with your car let me know.
Old 05-11-2010, 12:58 PM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
The only two carb builders/tuners I have used are http://www.davinciperformance.com/ and http://www.pro-system.com/
Both are outstanding tuners/ fuel flow designers. both make a auto cross specific carb.
Old 05-11-2010, 01:10 PM
Pro Systems 830CFM DP.
Same carb they recommended for my engine. Similar specs as yours.
Also try an Edelbrock dual plane intake manifold. Great all around use. Street and autocross.
Old 05-11-2010, 01:16 PM
What am I looking at price wise for a pro systems carb ? Also any recomendations the ignition?
Old 05-11-2010, 01:45 PM
Original road racing carb would of course be a Holley with center pivot float, which I'm considering. Intake, in my case, has to be a high riser to match the heads. Now thats where it get's tricky, I've seen some heads that claim to be a high riser, but in fact they are using a different definition of the word(s) and the ports don't match the "real" high riser heads.
Looks like $500 to $700 for a GOOD carb, ball park. Blykins, what kind of price range you talking about?
Old 05-11-2010, 02:56 PM
dcdoug's Avatar
Here's one at Carl's Ford:
427 NOS 1X4 HI RISE C4AE-9425G WITH 3255-1 HOLLEY CARB BRAND NEW NOS
http://www.carlsfordparts.com/main.h...n.html~content
www.partskeeper.com
Old 05-11-2010, 03:33 PM
Holy Cow!!! $1,300 for that setup. Yikes!
Thats three new Avons.
Then of course you would need a Turkey pan, another $400 or so. Course, I could use a "real" Turkey pan....
Old 05-11-2010, 03:50 PM
dcdoug's Avatar
You were talking $600-$700 for just the carb, so with the intake didnt seem that bad.
www.partskeeper.com
Old 05-11-2010, 04:14 PM
Throw in another $100 for linkage, grand total pushing $2,000.
Eh, maybe I'll wait...
Old 05-11-2010, 04:16 PM
dcdoug's Avatar
Although it does seem to be NOS stuff.....that's always a nice to have. I'm tempted to see if they have another one of those carbs lying around.....
www.partskeeper.com
Old 05-11-2010, 04:32 PM
Excal,
For a Quick Fuel Q-850, you're looking at around $625 + shipping. These are basically drag race carbs, no chokes, billet metering blocks, mechanical secondaries, jet extensions, etc.
On your engine, I would probably go with a Victor FE if you're going to be doing a lot of road racing.
On Mark's engine, a Victor Jr would be ideal in my opinion...427 cubic inches is enough volume to tame down a single plane intake.
Old 05-11-2010, 05:08 PM
Excal,
even on a small block?
Old 05-11-2010, 05:09 PM
Absolutely.
