Old 06-28-2010, 05:42 PM
Cobra Make, Engine: 351 Windsor
Default Spark Plug Wires???
I've noticed my engine running a little rough. Thought it could have been bad gas or carb. flushed the tank changed the filter and cleaned the carb. Ran fine for a while on some short trips. Had the car out this weekend and started the rough idle again almost to the point of stalling. Used an ohm meter to check each wire. Found 3 wires that read around .54 ohms. The rest read anywhere depending upon the length of plug wire was between .65 and .82+/- Does this sound like the problem of rough running and idle. Plug wires age ???? Original to the car and I have had it 3 years. Am I on the right track? The engine is a 351w. THANKS!
