Old 07-15-2010, 08:43 PM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Wiring turn signal indicators
My wiring did not come with detailed instructions on what to do with the turn signal and high beam indicator wires. I am going to assume that i should splice the turn signal wires into the turn signal wires that go to the steering column and splice the high beam indicator wire into the high beam lamp wire?
Is that correct or am i totally off base.
Old 07-15-2010, 10:56 PM
LMH's Avatar
LMH LMH is offline
Have you seen this? Not sure if it will help you or not but check it out anyway.
Alba gu brąth
Old 07-15-2010, 10:57 PM
LMH's Avatar
LMH LMH is offline
And this too: http://www.kirkhammotorsports.com/ma...merrelay.shtml
Alba gu brąth
Old 07-19-2010, 04:37 PM
Thanks, this was actually for a different car. Simple splice in and everything works great.
