December 2025
Old 09-27-2010, 09:56 AM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Shaky rearview mirror
I guess this is a common problem but my rearview mirror is pretty shaky where it is on the top of the dash so I'm moving it to the middle top portion of the windshield. I bought a bracket from Dark water but I'm waiting for it. Will it solve the vibration problem. Also I found by having it on the dash,it was blocking my vision when I was turning into a street,couldn't see the curb,had to duck down a bit to see,don't want to scrape my Team 3's. Anybody experience the same thing or something similar. Thanks
Michel
Old 09-27-2010, 10:01 AM
Michel, I have the DWC mount for the top of the windshield. For the most part it works great. It only really vibrates when I get on the throttle, and usually at that point my attention is on what is in front of me!
Old 09-27-2010, 10:34 AM
Rick Parker's Avatar
Doubt that will solve the mirror issue. The top of the windshield moves around quite a bit also. Maybe you should address what's causing it to shake? Maybe tire balance?
Rick
Old 09-27-2010, 03:04 PM
I have the finishline center rod with mirror and even at a idle it shakes. I need a high mount so I can see out of the hardtop but I will have to come up with a different mount. It might have something to do with .610 lift!
Cheers Greg
Old 09-27-2010, 05:57 PM
It shakes a bit but it doesn't bother me that much,it's suppose to shake,it's a hotrod right ?
The major reason I want to mount it higher is the vision issue. Since I'm short,I can't see over it when I take a corner and it creates a blind spot so mounting it to the windshield will solve the vision problem,for the shaking,I don't care,I still can see who's NOT following me.
Michel
Old 09-27-2010, 06:52 PM
mdross1's Avatar
Redid my dash mount rearview made it 2 1/2" taller to see out back with top on, hoping it will not vibrate.
Old 09-28-2010, 05:46 PM
Maybe they all vibrate beeing mounted on fiberglass,unless you beef up underneath with some steel plate,that could help,I don't have a roof so I will try my windshield bracket that I've got to see the difference. For me it was also matter of safety.
Old 09-30-2010, 06:16 PM
Got my windshield bracket and I have to say,good noticeable improvement.
A lot less shaking and a much better view and now I don't have to move my head sideways to see where the curb is. For my application,the bracket could have been a little wider where it attach to the windshield but I did a 45 minute drive and it stayed solid. I might make a better one later,maybe if I run out of stuff to improve.
