November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-04-2010, 09:17 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Default Soldering jets
I am experimenting with Idle jet holder sizes on Weber carbs. I want to plug the larger hole and re-drill a smaller hole. Can I use regular resin core plumbing solder or should I use silver solder? This will be a perminate fix since the holders sell for $12.95 x 8!
Snakebit
Old 10-04-2010, 09:19 AM
Wouldn't a little JB Weld be easier?
Old 10-04-2010, 09:39 AM
CobraEd's Avatar
I have soldered brass Holly jets shut and then drilled them to the diameter I wanted. It works fine.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 02-10-2011, 07:15 PM
Default soldering jets
Ive done just that. You must ream the drilled hole. You can fashion a needle or round toothpick,use rubbing compound, must be a 30/60degree crosshatch pattern just like a cylinder bore.no silver solder. 30/60long explaination here.e-mail me if you have problems sincerely lawrencex@att.net
Old 02-10-2011, 07:19 PM
[quote=lawrence cyburt;1109085]Ive done just that. You must ream the drilled hole. You can fashion a needle or round toothpick,use rubbing compound, must be a 30/60degree crosshatch pattern just like a cylinder bore.no silver solder. 30/60long explaination here.e-mail me if you have problems sincerely lawrencex@att.net
Old 02-10-2011, 07:21 PM
Cobra Make, Engine: jbl
i've read of people doing this, haven't tried it. would acid core be more appropriate and resin core for electrical?
Old 02-10-2011, 07:23 PM
Ive done just that. You must ream the drilled hole. You can fashion a needle or round toothpick,use rubbing compound,must be a 30/60 degree crosshatch pattern, like a cylinder bore. No silver solder.30/60 long explaination here. e-mail me if you have problems sincerely Lawrencex@att.net
