Old 10-29-2010, 02:16 PM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Everything gives you cancer. Get a cobra and have some damn fun.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 10-29-2010, 03:05 PM
charles roybal's Avatar
Cobra Make, Engine: FRR MKIII 408w
[quote=pusherfans;1086446]someone told me that it is unhealthy to drive in a car with side pipes next to your head, because you could get lung cancer from the fumes.
QUOTE]
Only & only if you put your mouth at the end of the pipes....and inhale!!!!
Old 10-29-2010, 05:07 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Don't know about cancer, but my SL600 gave me neck problems from the acceleration, and I'm afraid the Cobra will be worse.
Old 10-29-2010, 05:16 PM
WardL's Avatar
Diesel exhaust is carcinogen. Gasoline fumes and gasoline engine exhaust are NOT particularly carcinogenic. Benzene is found in gasoline and it is a carcinogen. The EPA is requiring gasoline to have substantially lower benzene in gasoline starting in 2011. It is not good to breath too much of almost anything. Second hand smoke is much worse than gasoline. Besides, I'm sure you are more likely to die in a Cobra crash than of Cancer from breathing exhaust gases. Back in the old days you used to be able to run your car in the garage and dye of carbon monoxide poisoning. Catalytic converters changed all that. Our Cobras will generate plenty of CO to kill you in your garage.
Old 10-30-2010, 04:38 AM
dcdoug's Avatar
Even if it did, you are just killing the people in the cars on either side of you.....
www.partskeeper.com
Old 10-30-2010, 06:52 AM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Default Not to put a fine point on this comment, but
I can understand some carbon monoxide concerns (try to keep air moving) and hearing loss (wear ear plugs), but is cancer a realistic possibility?
I'm no doctor. . .
thanks
my SPF does not have the side pipes next to my head, they are placed about three feet below, and thus when travelling the fumes would dissipate. The only thing I inhale is the free air that is blowing in my face. tin-man
Be well, drive fast, live long
Old 10-30-2010, 07:26 AM
I guess the most obvious observation is that if you're driving with the side pipes next to your head you're probably doing it wrong.......
Old 10-30-2010, 07:43 AM
FWB's Avatar
FWB FWB is offline
the sulfur dioxide coming from a catalytic converter will kill you quicker than exhaust from your cobra.....
Fred B
Old 10-30-2010, 07:57 AM
RestoCreations's Avatar
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Those guys that work the pits at NASCAR are screwed.
Old 10-30-2010, 08:15 AM
that's a good point. We don't hearof an unsually high lung cancer rate among race car drivers. . . . .
I think that's the proof right there!
Old 10-30-2010, 10:14 PM
67FEfastback's Avatar
I did hear of a Fountain powerboat dealer (at least 15 years ago) got cancer in the hair follicles just at the top of his forehead. Went into his brain, that was that.
Made me always try and wear a hat when boating. Not sure if this same thing would apply in a cobra or convertible, because there is no reflection off the water etc. Sounds very rare, still easy to take steps to prevent
http://youtu.be/1x63nB64zyM
Thunder
Old 10-31-2010, 06:19 AM
mdross1's Avatar
I would be a lot more worried about the ringing in my ears getting worse than lung cancer.My exhaust does exit the rear of the car not for cancer but for the looks,ease of getting in and out of the car,and personally the car looks great with belly exhaust.
  #33 (permalink)
Old 10-31-2010, 07:52 AM
DonC's Avatar
Classic example of someone who's "just asking for a dose of cancer" from breathing the exhaust fumes. He may be at less risk since he doesn't put a whole lot of miles on his car but says that will change as soon as he gets his periscope perfected.
DonC
  #34 (permalink)
Old 10-31-2010, 10:21 AM
WardL's Avatar
The EPA has forced the reduction in sulfur in gasoline too. It used to be limited to 1,000 ppm, but starting in about 2006 (?) the max is 80 ppm and the average is less than 30 ppm sulfur in gasoline. The benefit of lower sulfur is not to reduce the sulfur dioxide in the air, it is to help the catalytic converters to last longer. It is a good thing.
  #35 (permalink)
Old 10-31-2010, 11:40 AM
Jamo's Avatar
Super Moderator
Three pages...really?
Jamo
  #36 (permalink)
Old 10-31-2010, 06:50 PM
Senior ClubCobra Member
That's what happens when people O.D. on exhaust fumes or Halloween candy.
  #37 (permalink)
Old 10-31-2010, 07:26 PM
CBattaglia's Avatar
You have to admit this will be a memorable thread.
  #38 (permalink)
Old 11-04-2010, 01:55 PM
mdross1's Avatar
My only health issue would be lack of blood to the grey matter,since every time I climb behind the wheel the blood rushes to the pelvic area.
  #39 (permalink)
Old 11-04-2010, 02:30 PM
Leecbr's Avatar
Cobra Make, Engine: Factory Five MK4 427 roadster
I think I would be worried about the outside air quality. Like inversion, city pollution, or large diesel pickups with there tail pipes next to me. My guess, any health threat sitting in a cobra for under 5 thousand miles a year would be minimal.
  #40 (permalink)
Old 11-04-2010, 07:36 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
I hope you're not a smoker ??
I'm no doctor. . .
thanks
