Old 01-03-2011, 06:21 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Bending Turn Signal Lever
I read a thread somewhere about bending the turn signal lever when using a VW style lever/switch. I've searched all over but still can't find the thread.
I know the lever is made of pot metal and probably powdercoated. Does anyone have any experience or tips on doing this. I am looking to get a little more clearance between my hand when on the steering wheel and the lever
thanks
Paul
www.65shlb.com
www.prdcrrct.com
Old 01-03-2011, 06:49 PM
Hitch's Avatar
Cobra Make, Engine: BackDraft Racing 351W bored and stroked to 427 hydraulic full roller
If your turn signal switch is anything like mine I would advise against bending the pot metal that it is formed from. I'm not sure that even heating it would be a good idea. On mine though the switch is mounted to the steering column mast via a set screw. If you loosen the column and slide it towards you then you could loosen the switch set screw and move it away from you. JMO...
The cruiser and the bruiser... you decide...
http://img.photobucket.com/albums/v1...e/IMAG0417.jpg
Old 01-03-2011, 07:03 PM
Maybe instead of bending you could cut it shorter and add a new knob.
Happy New Year
Bruce
Old 01-03-2011, 07:42 PM
I don't think you can bend pot metal.
" It ain't no big deal"
Old 01-03-2011, 09:24 PM
Cobra Make, Engine: Kirkham and Hurricane Dealer in Mexico www.kitcarsmexico.com
Send a message via Skype™ to Kit Cars Mexico
I just put a spacer between the steering wheel and hub.
Old 01-04-2011, 04:17 AM
I used to successfully bend the (SWF-brand) levers but I'm not sure whether I'd trust the current ones. And I won't experiment until I get a bad one back...
Old 01-04-2011, 05:15 AM
Bill Bess's Avatar
Paul, I think we have the VW style turn signal and it won't bend. I installed mine on the wrong side (left side) like American cars, just cuz I wanted it in a normal position. The only problem is it's kind of close to the body, but I've had no problems, and the steering works good for me.
Bill
mickmate's Avatar
I've extended and repainted steering hubs and also just replaced them to get the right length. That is a place you need a little paw room and by the door just in case you ever need a little lock to lock action.
mickmate
http://www.actoncustom.com/
