Old 02-22-2011, 04:34 PM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
Default Exhaust Collector Sealing
Has anyone tried this; http://www.superlogics.com/adhesives...5/259-1499.htm as a seal/gasket between the primary header and the collector?
Old 02-22-2011, 07:35 PM
bobcowan's Avatar
Probably a lot more than you need. Remember that some day day you'll want to take that apart.
I use simple clear bath tub silicone sealant. Seems to be working fine, it's cheap, and it's clean.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 02-22-2011, 11:09 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
I don't think there is much tub sealant left after the engine comes up to temperature. It is only good upto ~350F.
I have used "copper gasket" and had good luck with it.
I believe the true key to getting a good seal is making sure the surface is flat. I have used a standard block and sandpaper. Color the surface with a black sharpie, dand until the black goes away.
Old 02-23-2011, 04:43 AM
mkassab's Avatar
Cobra Make, Engine: Unique 427 S/C, 427ci
Use the Red (high heat) RTV silicone sealant.... you can get it at any auto supply shop. Just clean both halves, put a bead around, bolt it up and let dry for 24 hour.... you good to go. A good portion will squeeze out.... don't touch it until it dries.... the cut it away.
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
Old 02-23-2011, 07:51 AM
bobcowan's Avatar
Actually, the clear tub sealant is working quite well. Not just at the collecter flange, but on the header flange as well. It's probably got about 12-15 heat cycles, and 1000 miles.
.boB "Iron Man"
Old 02-23-2011, 08:52 AM
GT350Mike's Avatar
Cobra Make, Engine: CSX6363
I recall seeing a post on this site where someone had success with a paste that Harley guys use on their exhaust. I'm sure that its not as cheap as the tub sealant but should work as well.
