Old 02-24-2011, 07:47 AM
Cobra Make, Engine: Factory Five, 427W
Default timing issue
I had a oil leak on the front of my intake, so I remove distrubor and intake and put new gaskets on intake, were I have my problem is I marked the distrubor but forgot to mark were the rotor button was when I pulled it, now I'm out of time.Any quick way? I'm thinking of pulling valve cover on the number one side and bump it until it comes to TDC and then point rotor on number one on distrubor cap?Then put light on it if it will start..ideas????
ff#5501 427w,TKO 600,P/S,Hydroboost,4wheel cobra disc/C Narrowed Mach1 rear, Moser axels,3Link,I Squared
Old 02-24-2011, 07:56 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Pull out the no. 1 spark plug, put your finger over the hole, turn the engine over by hand until pressure develops. Look at your timing mark on the front and adjust to 0 deg TDC.
Now align your rotor of your distributor to point to no. 1 spark plug wire and re-insert.
Point the timing light and your done.
This saves you from the mess of pulling the cover.
Old 02-24-2011, 08:01 AM
To pull my hand I will need to pull all plugs? The compression is high...
Old 02-24-2011, 08:23 AM
lnfletcher's Avatar
Not if you turn it slow. Just no 1 plug. All your testing for is for the compression stroke on the no 1 cylinder.
Old 02-24-2011, 08:39 AM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
When he says turn by hand he means with a socket on the balancer bolt and a long ratchet or breaker handle... or a friend could bump the starter for you...
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
Old 02-24-2011, 08:53 AM
lnfletcher's Avatar
Sorry, I assumed too much.
I wouldn't suggest the bumping starter method with your hand down in the engine compartment, but you could be very careful.
Just remember to remove the wrench before you test start it! (don't ask why I say that.)
Old 02-24-2011, 09:15 AM
I just thought that with the compression I have it would be hard to (turn my hand) wrench...I got it
Old 02-24-2011, 10:12 AM
lovehamr's Avatar
Stolen Avitar
As you rotate the engine VIA the long ratchet you'll hear the compression leaking by the rings in the sealed cylinders. As it leaks down you'll be able to turn it. You won't be able to turn it fast but then you should only need to turn it less than 2 revolutions.
Steve
Old 02-24-2011, 04:58 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
You can also rotate the engine by putting it in 4th (1:1 gear) and pushing the car forward. Avoid rotating the engine in the incorrect direction.
Bob
Old 02-24-2011, 07:23 PM
lovehamr's Avatar
Stolen Avitar
I'd run over my own foot. Yes Bob, you know I would.................
