| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
05-21-2011, 05:25 AM
AR
Points source for early dual-point distributor
Does anyone have a recommended source (and part no.) for quality points for an early 427 dual point distributor (1963 or 64)? I would prefer something like Accell if available. Considered running Petronix in it but just too many stories of the units and their coils crapping out regularly.
Thanks
05-21-2011, 07:02 AM
Ill
A alternate choice is the 6 cylinder points are the same as the duals(if I remember correctly) and also usually just one set actually goes away as the current arcs on the break set and the make set survives.
If you can find them--both accel and mallory were the ones I preeferred
05-21-2011, 07:08 AM
Dan ... you might check with Keith Craft Racing , Barry at Survival etc as to a source for the points . Don at FBO is also a possible source .
I`m running the Petronix in my 63 1/2 427 Galaxie ... and have for almost 10 years and haven`t had any problems . However , I don`t run their coil ... and also carry my original plate with the points and condenser on it just in case . I sent my distributor along with the coil to Don Gould at FBO Systems in Cottage Grove ( 541-942-5920 ) to have it recurved . He checked to coil on his machine and furnished one that matched his specs on rise time etc . You`re right ... the original was junk . Car is much more responsive since the distributor rework .
BTW ... I`ve heard that the newer Petronix systems ( made in China ?? ) have reliability issues .
Bob
Stolen Avitar
GA
Dan, are you running an MSD box? If so then you only need one set in the dist. and it'll last almost forever because it'll only be carrying a few miliamps.
Just a thought, Steve
05-21-2011, 07:51 AM
CT
Cobra Make, Engine: HM-2027 / 427 SO
Tim O'Conner hooked me up with some HD points for my DP distributor. Tim O'Connor Distributor Rebuilding and Restoration - Home Not sure what brand they are but very reasonable and a great vendor for parts and distributor restoration.
05-21-2011, 08:53 AM
Dan ... just remembered . Go to the FEForum and do a search on distributors . There is a ton of info and sources for everything from parts to complete rebuilders on there .
Bob
05-21-2011, 11:13 AM
MD
Originally Posted by FFR428
+1 for Tim. He's got just about anything you would ever need for a Ford Distributor and is very helpful.
www.partskeeper.com
05-21-2011, 12:37 PM
Ca
If you want the nostalgic look of an OEM Ford distributor, that's cool, BUT do yourself a favor and repalce the inards with that from a mid 70's electronic Ford distributor (fits without any hassle, never any maintenance either.
Rick
05-21-2011, 01:08 PM
AR
Thanks everyone. Sounds like Tim may be the lead I need. Although I dissassemble the distributor and cleaned it up I would like to have a pro look at it and check the advance curve. I'll give him a try.
Dan
05-21-2011, 01:16 PM
AR
Bob
Keith built my engine but I don't think his guys like dealing with anything but the new MSD electronic stuff. He messed around with it a little but claimed they couldn't keep the points gapped right and gave up and dynoed the motor with a spare MSD unit. They weren't sure where the points they used came from and I just think they didn't want to spend time on it. I checked over the distributor again and I can't see any reason it shouldn't hold dwell - looks nearly new inside and it's tight.
No MSD box. Just points, condensor, ballast resistor and coil.
I'll keep Don in mind if Tim doesn't work out.
Thanks
05-22-2011, 10:05 AM
MD
i used a Petronix points replacement on my dual point to make it easy. Just a thought. Can't tell unless you open it up. Tim can check your curve as well as the distributor components.
www.partskeeper.com
05-22-2011, 10:34 PM
Ca
Rick
05-23-2011, 06:44 PM
AR
Originally Posted by Rick Parker
I sent the distributor off to Tim O'Connor today and I'll see what he comes up with. But, I appreciate the lead on the points set. I'll file it away for the future.
Dan
