Old 06-22-2011, 07:47 PM
Newsnake's Avatar
Cobra Make, Engine: Unique 289 FIA, 302
Default Ceramic coating for side pipes
What are the best ways to have your side pipes Ceramic coated to manage heat?
Also where is a good place to have it done?
West coast would be preferable but not essential.
Thanks
Old 06-22-2011, 09:15 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
You just have to of course remove your pipes and bring them in to whom you choose. Most powder coating shops do ceramic coating as well.
" It ain't no big deal"
Old 06-22-2011, 11:01 PM
Rick Parker's Avatar
Here is a good place in a suburb of Sacramento
AIC Amerikote Powder and High Temp Coatings
Rick
Old 06-23-2011, 06:45 AM
I met these guys at the Sacramento Show. They were very helpful and their work was beautiful. CAPS Coatings
Old 06-23-2011, 12:54 PM
HI Cobra's Avatar
If I could find a place hear on Oahu, HI to do mine, you should be able to
find a place in CA. Had my headers and side pipes coated for $300 about
4 years ago and they still look great. It is much cooler now and not nearly so
easy to burn the legs - you will be glad you did it.
Flip
Old 06-23-2011, 08:42 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Make sure that they are perfect. Once you ceramic coat your heaers and or sidepipes any changes or repairs by welding or cutting , the ceramic coating will need to be removed at site of repair and the whole lot done over again. My headers were in two pieces per side. Side pipes were non glass pack type. I had the EM muffler, lobak. and open pipe, side pipes and had all three sets done. All done inside and out. I have SS "V" clamps and flanges for all three sidepipe pairs and turn out pipe.
You want the pipe material as clean as possible. The coating outfit will clean and sandblast to get a clean and ruff surface for ceramic coating to cling to. Once coated and cured they will tumble in media to polish outside surfaces. They will charge more for any out of the norm condition that cause them more work. I had the polished alluminum creamic coating.
Mike H
