Old 08-27-2011, 06:35 AM
Rawkkrawler's Avatar
Cobra Make, Engine: Everett Morrison
Default Solid or Hydraulic?
So I've been adjusting my valvetrain for the past year assuming (was told) I had a solid lifter FE 428. Today I found this. Looks like a two piece lifter with a spring in between. Is this a type of solid or is it hydraulic?
Side note: I pulled it out because 3 of the 16 had a retaining clip that came loose.
Mike D
Tampa Fl
Old 08-27-2011, 06:37 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Hydraulic...
Jack
XSSIVE .....
Old 08-27-2011, 07:40 AM
Huh. So you've been running your hydraulics with, say, .018" lash, but it probably didn't keep that lash, which I can see throwing you for a loop. Well, probably no real harm done and now's a good time to change out the cam and lifters to something you'd really like (and know what it is). You might check in with Blykins -- he's a recent convert to solid flat tappets for his own personal build and he will no doubt give you a nice deal on a nice package.
Old 08-27-2011, 07:53 AM
No convert here and the guys that want to run a cam like mine are going to be in for a lot of expense.
How do the lobes look? Are they damaged? If the lobes look fine, then you can throw a new set of hydraulic lifters in there and do the break-in dance.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 08-27-2011, 09:08 AM
That's what I figured.
I did have a few that wouldn't keep a consistent lash
Lobes look good at least.
Brent, looks like I may be doing that intake/carb and now cam swap we talked about a few months back.
I'll be giving you a call.
Thanks everyone for your input!
Mike D
Tampa Fl
