Old 08-25-2011, 04:41 AM
mreid's Avatar
Default Hydraulic clutch question
I have a hydraulic clutch with an external slave push cylinder. It is mounted on a bracket attached to the Quicktime bellhousing using an FE style fork (pivots on the driver side), TKO600, 351w based engine.
Do I need a return spring to pull the fork back?
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 08-25-2011, 04:46 AM
mkassab's Avatar
Cobra Make, Engine: Unique 427 S/C, 427ci
You shouldn't need a return spring if all is working fine.... but, having said that, a spring can't hurt.
Are you having a problem, e.g, clutch not fully engaging?
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
Old 08-25-2011, 06:15 AM
No, you do not. The clutch pressure plate will force the fork back to it's original position.
That said, make sure the slave pushes the fork in a straight line. Not at an angle. Otherwise you will invite throwout bearing failure.
