| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
09-08-2011, 02:43 AM
IL
Cobra Make, Engine: ERA 454 S.O.
Black Side Pipe Coatings?
For those of you that have black side pipes. What coating did you use? What type of finish are they (gloss, satin, flat)? Are you happy with them?
Thank You
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
09-08-2011, 07:37 AM
Jet Hot.
Satin.
Yes.
They are 17 years old now and look like they'll last another bunch of years.
David
09-08-2011, 07:44 AM
WI
I started out with silver ceramic coating on my pipes, but one day while trying to clean them back to their original sheen, I acted on impulse and painted them rattle can hi-temp gloss black. They're easy to touch up occasionally (due for a touch up now actually) and not only does the car look meaner, I think it goes faster now too.
Tropical Buzz
09-08-2011, 07:46 AM
tx
Cobra Make, Engine: FRR MKIII 408w
I used engine block paint only last 2,000 miles they look like this...have to re-do.
Charles Roybal..."Drive with your lights on!!!!"
09-08-2011, 10:37 AM
IL
I didn't know a spray can can give a perforated look.
Jeff
Mark Donahue
09-08-2011, 03:34 PM
CT
VHT (flat) black header paint. 8 bucks a can, which lasts a couple of years. Touch up when needed.
09-08-2011, 04:57 PM
Az
Cobra Make, Engine: ERA FIA #2119
BBQ spray, (flat black) good for the temps, last a long time. There is no smell of BBQ sauce or of anything cooking unless your leg just touched it.
09-08-2011, 05:09 PM
ca.
Cobra Make, Engine: B&B 306/FORD
Vht header paint flat black
09-08-2011, 08:13 PM
AL
ceramic coated pipes
my ceramic coater call these dark gray, look's flat black to me.
Dwight
09-08-2011, 08:20 PM
TX
Mine are a shinny flat black.....
Gary
CAV GT40
09-08-2011, 08:57 PM
IL
Mine are sivver ceramic coated already. What do you think, skuff them first with say 280 grit? Primmer? I know nothing about paint.
Jeff
Mark Donahue
09-08-2011, 09:39 PM
Ca
280 might be a little coarse, maybe something between that and 400??
Rick
09-09-2011, 06:06 AM
Rick-beautiful headers. How do you get #6 plug out??
Chas.
09-09-2011, 07:50 AM
Ca
With an extension and swivel. It's got more room between the pipe and V/C than it appears to have. The headers work very well .
Rick
09-09-2011, 07:24 PM
CT
Use some Scotch-Brite & wipe clean. No need to prime, just some VHT black header paint that you can get at Pep Boys, Advance Auto, etc. You'll have to touch it up every-so-often. I use cardboard pieces behind the pipes to mask the body.
09-09-2011, 09:41 PM
IL
Sweet.
Jeff
Mark Donahue
