Old 01-02-2012, 05:52 AM
DougD's Avatar
Default Roll Bar grommets?
What is everyone using for the spacer between the roll bar and body? I've seen rubber ones, stainless steel ones, etc. Please post pics and where you bought them. Thx.
Old 01-02-2012, 07:46 AM
Karl Bebout's Avatar
Finish Line in Florida has very nice rubber gromets and polished bezel sleeves in a couple different tube sizes, both round and oval.
Karlos
Old 01-02-2012, 12:34 PM
Cobra Make, Engine: Former Everett-Morrison,428SCJ
Hi Doug,
If you have access to a lathe, you can make them for about 25 cents each......I left about 1/16 inch gap between the bar and the grommet. The grommets are glued to the body with clear silicone, then a bead gets run in the bar to grommet gap. It's a cleaner look than you get with the rubber ones, which is what I was after. (Also helps justify owning a lathe
-Jon
Old 01-02-2012, 01:54 PM
mickmate's Avatar
Hey Doug, I have the 1.5" grommets for the hoop and I make them for the rear brace from slit vacuum tubing.
mickmate
http://www.actoncustom.com/
Old 01-03-2012, 06:08 AM
DougD's Avatar
Nick
I do like the look of the rubber vs polished metal. Seems cleaner and simpler to me. Doesn't draw you eye to them as much. What size hole is needed in the body?
Old 01-03-2012, 06:52 AM
mickmate's Avatar
1-3/4" I bevel the underside edges of the hole for a good grommet fit.
mickmate
Old 01-03-2012, 02:25 PM
1985 CCX's Avatar
Hose is old school and the way I will go!
Old 01-03-2012, 03:03 PM
Cobra Make, Engine: shellvalley 428 ford
Here is a couple of places to look at.
Rubber Product Distributors
AN931 ELASTIC GROMMETS from Aircraft Spruce
Byron W.
Old 01-04-2012, 06:15 AM
DougD's Avatar
Thanks, Byron.
