November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
View Poll Results: Stay True to Your Ride
good 3 42.86%
no good 4 57.14%
Voters: 7. You may not vote on this poll
Old 01-27-2012, 09:34 AM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Default Stay True to Your Ride!!
Until question of compatability is solved w/underover drives in roadster's I have removed Thread! Will post results asap!
Sry for delay
Old 01-27-2012, 10:13 AM
CHANMADD's Avatar
I have a Jag 4speed with a Laycock overdrive , with electronic control via a switch on top of the original Jag gearknob. I have had my issues with the unit over the years but generally it works great. I have had it wired so that it worked on all forward gears and like the factory only on 4th which makes it like 5th gear. The last way is the best and at 80mph I am doing just 2000rpm ( 2.88 rear). I did have Phospher/Bronze facings made for the cone clutch, which has been great.It does make the gearbox longer and the driveshaft shorter.
Old 01-27-2012, 10:28 AM
Originally Posted by Silversmith View Post
These things are awsome & will save Time & Money. Not to memtion adding 7, thats right, 7 forward gears. Take a look & let me know what u think??
Gear Vendor won't fit:
Chas.
Old 01-27-2012, 10:46 AM
CHANMADD's Avatar
Just quick....If I did it again I would use a 5 spd
Old 01-27-2012, 11:19 AM
Default DoHHHHHHH!!!
I do hope you are wrong!!! I have the guys @ gearvender's checking if the unit will fit with the ERA std. Jag rear end! I hope, I hope I hope If it does; it will save so much time & cash! Not to mention, they are blast to use Will Advise, when I hear!!
Old 01-27-2012, 01:55 PM
Just show them my pic. Tunnel won't sit down, X-member is right under the trans mount. Driveshaft is about a foot long. They'll want you to eliminate the shaft -and it's safety hoop- and connect to the Jag yoke. Like a Cheetah-no driveshaft.
None of this is worth the effort and expense-the GV is about $1800 last I looked-more if you've got to pay to butcher your car. That's a few years worth of gas...
Chas.
