November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-03-2012, 05:40 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Missing bezels seals for my 45 degree roll bars
My rear (oblique) roll bars are 1.5 inch in diameter and I never got any seals for the bezels and was wondering what I could use,any suggestions that could work. I was thinking about tube from bycycle tires,do they make seals for those bezels. Back in the days they didn't have any but I have to put some because the straight bars have it so...Thanks for your suggestions !
Old 04-03-2012, 06:00 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
One solution is to use some small diameter rubber tubing - like fuel or vacuum line - and cut a piece longer than the entire circumference of the opening. Slit the tubing, fit it into the opening, and trim the ends to fit. That's what ERA provided for mine car.
Hal
Old 04-03-2012, 06:07 PM
Thanks Hal,that's a great idea and possibly the best way to go,that should work perfectly,thanks again !
Michel
Old 04-03-2012, 06:27 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
If you have Bezels then you can make the seals out of 1/8" neoprene. You buy it is various sheet sizes off Amazon.com
Old 04-03-2012, 07:22 PM
mickmate's Avatar
Slit tube as suggested with the end trimmed to length then super glued together.
mickmate
http://www.actoncustom.com/
Old 04-03-2012, 10:49 PM
Rick Parker's Avatar
Use 3/8" rubber radiator overflow hose. It is pliable and easy to work with.
Rick
Old 04-04-2012, 09:38 AM
Thanks guys for ideas,will go look around for those items,cheers !
