Like Tree2Likes
Old 04-06-2012, 01:51 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Default Vacuum Advance - ported or manifold
I run a 1969 351W in my roadster. The distributor has a vacuum advance pot on it that advances the timing as higher vacuum is applied. OK, where should the vacuum advance hose be plugged in, a PORTED nipple or direct MANIFOLD nipple? There seems to be so much controversy surrounding this question. From what I read, direct manifold vacuum gives me 22 degrees of vacuum advance plus 10 degrees initial timing at idle for a cooler idle with less NOx emissions but ported vacuum gives me only 10 degrees initial timing at idle, slower idle speed but causes not only vacuum advance but also centrifugal advance to increase as engine speed increases.
There must be some expert out there who really knows his defecation (s**t) who can set me straight.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Display Modes
