Old 04-23-2012, 07:26 PM
Default Breaking stub axels on my jag IRS....Help
I have a Jag IRS with a 9" head so solved 1 problem and moved it to axels. I am breaking axel shafts drag racing, dose anyone know what material is best to make replacements stub axels from??
Old 04-23-2012, 07:34 PM
CHANMADD's Avatar
The irs was never intended for drags. If you are serious about drags you should have got a car with
Live axle. Any reputable machine shop should non the less be able to make you some steel axles.
Old 04-24-2012, 04:01 AM
mkassab's Avatar
Cobra Make, Engine: Unique 427 S/C, 427ci
Contact Denny's Driveshaft company..... Dennys Driveshaft and driveline parts High Speed High RPM Balanced Steel and Aluminum Drive Shaft Specialist
They will and can make what you need.
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
Old 04-24-2012, 04:31 AM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
The Jaguar rear suspension was designed 40 years ago for 236 horsepower and a 700 series tire. It is ill suited for anything other than looking cool. Don't ask me how I know this
Old 04-24-2012, 04:35 AM
Mark Williams Ent. makes HD stub axles (30 spline) for the Jag.
Tags
axels, broken, irs, jag rear end
