05-21-2012, 10:01 AM
va
door latch needed
I am looking for a drivers side door latch,
Just need the latch that has the lever on it.
Hoping some one here may have a broken set laying around.
Any help appreciated.
07-21-2017, 07:00 PM
va
Reaching out to forum members,
Still need a drivers side door latch, anybody out there have an old one or set you may not use or need?
Thanks.
07-21-2017, 09:17 PM
NV
Ok so what have you done for the last 5 years?
CSX4005LA
07-23-2017, 04:08 AM
va
Been using a peace of string
07-24-2017, 07:15 AM
We always buy the latch/strikers in sets, and the most frequent failure is the latch. Finding a single latch for little $ isn't easy. I see that cobrarestorers.com has a separate listing, but it's not cheap.
Usually, if the latch comes apart, it's repairable if you get creative.
07-24-2017, 02:25 PM
va
this one has been my shop set for many years, one of the mounting ears has broken off.
Looks like when I place my next order I will add an extra.
Just like to use up what I have if at all possible.
07-25-2017, 04:23 AM
Originally Posted by cobrakiwi
So, you're not talking about the latch, but you need a striker instead. At least that's cheaper.
07-25-2017, 05:00 AM
va
No Sir, need a latch. All good for strikers
Here is a picture of a latch, (not the one in question), Top left mounting lug broken off (red circle), all the outside shinny bits are okay, just the main latch chassis needed.
07-25-2017, 08:10 AM
Could you just weld a piece of steel to the corner and machine it with a Dremel?
Weld it on, grind it flush and drill the hole? I have done this on pieces of equipment and it worked fine.
Flip
07-25-2017, 10:15 AM
va
Good thinking, but the material it is made of is a pot metal/die cast, tricky to weld at best.
Plus I don't have any compatible rods to give it a try.
