November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-09-2012, 09:11 AM
bobcowan's Avatar
I did the same thing this past winter.
You can't cut teeth into the balancer. The balancer is so wide that you will get an erratic signal. Look at a stock part - the toothed wheel sticks out further than the edge of the balancer for exactly this reason.
Adding a wheel to the front of your current balancer is not that big of a deal. You will have to add spacers to the other pulley components. Again, not a big deal. You can carve them out of some 1/8" alum without too much difficulty. I did it with standard hand tools.
Or, you might get lucky and find a stock balancer that will work for you. Then you could get the factory bracket and sensor, too.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
