January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-09-2012, 12:00 PM
DanEC's Avatar
Default Figures from dialing in bellhousing runout
I think these figures are going to be OK but see what you think? I'm running a Toploader, Quicktime and bronze pilot bushing. This was the second run. After the first run I loosened the bellhousing and tapped it in the direction it was closest to centerline and then re-torqued the bolts again and re-measured. It appears this shifted it about a thousand.
Top .0128
Left .0155
Bottom .014
Right .0115
The fourth diget was just an interpretation when the needle fell between marks. Six thousands was what I remember from long ago as barely acceptable and I'm well within that.
Dan
Old 06-09-2012, 02:26 PM
FWB's Avatar
FWB FWB is offline
while i have no idea what is acceptable or not...even though i have slept at several holiday-inns over the years...
but 6 thousandths is .006 your measurements are about twice that....
Fred B
Old 06-09-2012, 03:26 PM
Gaz64's Avatar
Dan,
Your measurements are vague, measured in respect to what?
The point of alignment is the input shaft HAS to be in line with the crankshaft.
Your numbers are twice of .006, and .006 is too much off centre in my book.
Your bellhousing and/or block doesn't have dowels?
Gary
Old 06-09-2012, 04:49 PM
DanEC's Avatar
Originally Posted by Gaz64 View Post
Dan,
Keith Craft built motor - yes it has dowels. Measured with a magnetic base set on the crank flange and 1 inch dial indicator reading at 90 deg intervals around the bellousing register for the transmission. Numbers have to be divided in half for runout so they are well under .006.
Old 06-10-2012, 02:48 AM
Gaz64's Avatar
Dan,
I see how you do it, you are well under max spec.
Gary
Old 06-10-2012, 03:37 AM
Default You can't have 4 numbers in the plus
DanEC Dan the spec you are looking for is .000" Have not ever seen this. If you can get down to .003" you are good. This is top to bottom and side to side. 2 of the numbers need to be negitive. The easy way is to buy the offset dowel pins and have them install and setup the bell this way. I did it the harder way with grinding out the holes, centering the bell and welding nuts on the locators for repeat assembly and bell being centered. It took 2.5 hours to get this correct. My lakewood was .038" out. I am down to .002"-.004", close enough for me.
Best thing to do is install flywheel, setup magnetic base and dial gauge and retest your measurments then come back with the numbers and we can see what off set dowels you need to get this setup into spec. 2 numbers plus and 2 numbers neg. You know which way to move bell. Once this is done, torque bell to block and get dowels install and twist to match holes. If you have the room, drilll and tap holes for bolts or allen head screws to lock the dowel in location. You are good to go after this. Rick L.
Old 06-09-2012, 03:40 PM
If those are numbers read directly from the dial indicator, your runout is about 0.002" left-to-right. That's a very good number, not requiring offset dowels.
Old 06-09-2012, 04:46 PM
DanEC's Avatar
Yes that's correct. I didn't try to zero the dial indicator. I just set it to read and then took readings at 90 deg intervals by turning the crank. Top to bottom absolute figure was .0012. Left to right was out .0040. Runoout would be half of that figure or .002 in and .0006 in (.001 rounded for all practical purposes).
After posting I realized I had not put in the adaptor ring in the bellhousing that the Toploader requires. I re-ran the figures with the adaptor ring in and they didn't change much althogh the ring was very slightly elliptical I found out by spinning it around in the opening and reading the stationary dial indicator.
Keith Craft was to dial everything in but I'm not too sure they didn't forget so I thought I better double check it.
Old 06-09-2012, 04:23 PM
charles roybal's Avatar
Cobra Make, Engine: FRR MKIII 408w
Automotive Tech Articles | Lakewood Bellhousing Alignment Procedure
Charles Roybal..."Drive with your lights on!!!!"
Display Modes
