Old 06-27-2012, 09:25 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Default Any one?
Has anyone experienced the steering column sticking at temperatures above 80 degrees F?
I have an IDIDIT column and when I was down in London, the column had sticking problems.
Would like to know what I can/should do.
Old 06-27-2012, 09:36 AM
Most likely it's the u-joints in the system. Check for play, wear. If not it's the bushing(s) in the column.
Chas.
Old 06-27-2012, 04:39 PM
Send a message via MSN to CowtownCobra
I was in a parade once and the ididit column got very hot, smokin hot, the end result was I could hardly turn the wheel. After it cooled down it was fine.
Old 06-27-2012, 09:14 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
I had a problem with my steering getting stiff after a while in hot weather. To make a very long story short, it turned out to be the rack. I could reproduce the problem on the bench with a heat gun. The rack was sticking in the passenger's side bushing at any temperature over 90* F. At 110* F it was vitrtually seized.
Jim
A Gnat! Quick, get a sledgehammer!
Old 06-28-2012, 10:27 AM
trularin's Avatar
Member of the north
Thanks!
A few of the guys in London said it was the IDIDIT, they had issues as well.
Since they are down the street and around the corner, I think I'll give them a call.
