December 2025
Old 07-03-2012, 07:30 PM
Cobra Make, Engine: Everett Morrison
Default Please need speedo help
Hoestly " I've tried everything
Autometer 180 reverse speedo. Test with drill works perfect
Brand new cable no kinks well lubed
Little device that reverses the turn " seems to work perfect
Take speedo off. Drive car. Cable turns perfect
Connect to speedo and drive """. Nothing
I just dont get it.
It all looks perfect. Am I missing something here?
I'm pretty fed up right now
Old 07-03-2012, 09:25 PM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Is your reverser turning in the correct direction? Most need to be reversed.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 07-03-2012, 09:30 PM
It was working fine.
Just died
Old 07-04-2012, 06:25 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
If your reverser is the same as mine (screws to the back of the Autometer speedo) there is a square shaft in the housing that transfers the input rotation to the speedo. Mine was binding and broke the cable the first time it was used. I had to shorten the shaft slightly and, with a little grease, that took care of the problem.
Bill
Old 07-04-2012, 06:52 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Make sure the short cable coming from the reverser to the speedo is turning when the car is moving, if not, it might be the plastic gear on the end of the cable at the transmission is not clipped on properly. You can get the parts at PATCO.Com
Good luck, Bill
Old 07-04-2012, 07:13 AM
mickmate's Avatar
These guys have sorted it out for you already. It's either not engaging or it's spinning it in the wrong direction, as in it doesn't need the reverser. Some of them can be used as a 90 adapter instead of a reverser if you need the angle to align it.
mickmate
http://www.actoncustom.com/
