Like Tree6Likes
Old 07-15-2012, 11:34 AM
Got the Bug's Avatar
Default Knock Off Spinner Tool
I was looking at some of the video on Jay Leno's garage and came across a video about a spinner knock-off tool.
The lead hammer works fine for me. For those that remove their wheels often or are are concerned about torqueing the wheel to a certain spec, it might be worth looking at.
Jay Leno's Garage - Knockoff Spinner Tools | Tools
Sarto Rocheleau - Home
Doug
Old 07-15-2012, 12:19 PM
350 Ft/Lbs??? That doesn't sound right. Sarto Rocheleau - Home
EDIT -- The thought of using my portable battery powered impact gun on my wheels is kind of appealing.
Last edited by patrickt; 07-15-2012 at 12:49 PM.. Reason: Thought About Using My Impact Gun On Them
Old 07-15-2012, 12:57 PM
computerworks's Avatar
Lead hammer.
(...of course, I set points with a matchbook cover, so who am I to say. )
Old 07-15-2012, 01:05 PM
Silverback51's Avatar
Actually the 300 to 350 LB/FT torque is correct.
I was looking at buying some ForgeLine center lock wheels for my daily driver, and the torque requirement for those was 300 LB/FT.
But then I just could not see buying $7000 wheels for a $21,000 car.
Forgeline: Center Lock Wheels and Center Lock Conversion
John Hall
Old 07-15-2012, 02:13 PM
lovehamr's Avatar
Stolen Avitar
I might not have to point it out but you're not going to be getting 350# out of your normal 1/2 torque wrench either.
I just looked at the web sight and noticed that they sell torque wrenches as well................................. that only go to 250#.
If you just want a really expensive knock-off tool you could always go here:
http://www.grandtouringusa.com/index...mid=27&lang=en
Old 07-15-2012, 02:40 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Lead hammer.
Points? What are those?
Dave
Old 07-15-2012, 03:53 PM
DanEC's Avatar
[quote=lovehamr;1200337]I might not have to point it out but you're not going to be getting 350# out of your normal 1/2 torque wrench either.
I was wondering about that too. They probably need a 3/4 drive breakover bar to work with that thing. I use Sears long 1/2' breakover bar to loosen lug nuts on my pickup that I put on with a torque wrench (90 ft lbs) and it takes a little effort even with that long bar to bust them loose. Trying to loosen a spinner with nearly 4 times that much installation torque - I'm going to want about 3 ft of bar - minimum.
Old 07-15-2012, 04:06 PM
Just take the handle off your low profile floor jack and slip it over the half-inch ratchet. You get a nice three foot long wrench for mucho torque.
Old 07-15-2012, 05:57 PM
-enough to disintegrate the gears in a 1/2 ratchet and bash yourself with the car.
Don't do that.
KevinW likes this.
Chas.
Old 07-15-2012, 06:01 PM
Chas, since you're awake, what kind of torque do you guesstimate our spinners but down with the whacks from the lead hammer?
Old 07-15-2012, 06:38 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
By spinner tool you guys mean a hammer, right?
rodneym
Old 07-15-2012, 07:18 PM
I honestly don't know after wondering all these years. But I know it's two different types of torque.
The hammer provides a more instant type of torque-the k/o goes on by hand until it seats and movement stops. Then torque is applied by a whack or two.
I know that wrench-applied torque is more gradual and 150+lb/ft on the Jag hub castle nuts and 125 (IIRC) on an ARP balancer bolt (less with ARP lube). I did the Jag nut with a 3/4" and a pipe extension to get the wrench to click.
All this special, expensive k/o 'wrench' stuff is BS to make money for tool designers. Knock-offs were designed from day one for hammer activation.
Too many effete snobs with more cash than mechanical sensibility have given the astute a viable market to fleece.
It ain't rocket science-practice it and the feel comes and never goes away. The feel of applying torque to fasteners by wrenches is a far more sophisticated skill to learn.
If you've got one of these cars, using the hammer is the easiest requisite skill you should be able to master. Man up.
Chas.
Old 07-15-2012, 07:31 PM
Well, I'm sure when you were younger you could have mustered that without the extension.... Maybe we should double up now on your Fosamax.
Old 07-15-2012, 07:39 PM
-and discontinue your Dulcolax.
Chas.
Old 07-16-2012, 05:04 AM
DanEC's Avatar
I own a Corvette with knock offs and I've heard the 350 to 400 ft-lbs of torque or there-abouts from the Corvette Forum in the past also. I assume hammering on the ear until you get that solid twack is somehow regarded as consistent with that but it obviously leaves a lot of room for variation.
lovehamr's Avatar
Stolen Avitar
Damn Chas, that's rough even for you! LMAO though because you're prolly right..........
Old 07-16-2012, 06:39 AM
Dude, after a long time at this you get fed-up with the myths perpetrated on the unsuspecting and unknowing.
There was a guy on here called 'Mr. Fixit' who really knew and did everything. But you LEARNED how to and why things worked. He had zero tolerance for BS-made me look like Mother Theresa.
Hope he's still around and wish he was here.
Chas.
Old 07-16-2012, 06:54 AM
I remember Fixit...whatever happened to him? He had a bunch of good and helpful input.
Ken
Old 07-16-2012, 07:22 AM
He probably got tired of the BS.
Chas.
Old 07-16-2012, 07:31 AM
I miss Ernie (Excaliber) -- I think there should be a rule that if you've been on here for years you're simply not allowed to just disappear and never be heard from again.
