09-04-2012, 01:59 PM
Cobra Make, Engine: FFR, CHP 427w Streetfignter, Injected Venom.Mass-Flo...550 hp , 550 torq..spec pulley sys..
Liquid Octane boost suggestions!
I wanted to ask this here, vs the engine thread, to get the best and most solid answer. I was using a product, Liquid Horsepower, forget the name right this moment, but used it every other tank full and it really helped clean things up and didnt cause any issues with motor. Does anyone have a suggestion as to what works best on a High Performance 427W with 550 Hp and torque? I know I can hit pepboys and find options but you guys are way more in tune on these things. I am not trying to do anything special, just keep it running nice.
no torching here...........just a question.
fred z
Passion......"many things in life will catch your eye....but only a few will catch your heart......follow that one!"
09-04-2012, 04:00 PM
suggestion: find 110 octane gas somewhere near or order online. best bang for the buck
09-04-2012, 04:27 PM
What is your compression and timing that you need it? 550hp doesn't seem that extreme for a 427w combo.
AL
I don't think any of the small cans of octane booster you can buy at the auto parts store increase octane by more than about one tenth of a point (i.e., from 93 octane to 93.1 octane) when added to 15-20 gallons of gas. To see any measurable or noticeable change in octane, I purchased an additive that was sold in a roughly ten gallon container and delivered by freight. As best I recall, mixing it with 93 octane in a 9:1 (gas:additive) ratio increased the octane about seven or eight points to 100 octane. ... It's been a few years so I won't argue if someone comes forth with more accurate information.
PS: I think it was something like this: Hitrate
Tommy
Previously owned EM Cobra
09-04-2012, 04:44 PM
I actually dyno tested one of the popular products. I added the proper amount to a full tank of 93 octane - and lost 30 RWHP. I don't know if anything was "cleaner" - but I won't be adding anything to the tank ever again.
09-04-2012, 05:04 PM
SA
How about plain water. Years ago I installed water injection. I could advance the timing 5deg without pre-ign.
JD
09-04-2012, 05:53 PM
Jim Woodard
09-04-2012, 06:12 PM
AL
I can't tell from your post if you really boosted your octane or just added some of the usual over-the-counter stuff. In any case, boosting octane alone does not result in an increase in engine torque or power. What it does is allow you to tune the engine more aggressively (e.g., more timing advance) without suffering detonation. So, if you don't retune the engine after you raise the octane, you won't feel much difference. .. Unless you have a computer controlled fuel injection that automatically senses and adjusts for the fuel.
Tommy
09-04-2012, 07:35 PM
100% of the fuel additives to boost octane or power in your fuel are bogus. For 3 ounces in a gallon of fuel to boost it 10 points it would have to be over 500 octane. Maybe if it were pure tetra ethyl lead. Do you buy regular gas at 87 octane and with your Klotz additive you have 97 octane? How does your Cobra run on that blend? Your mind tells you the additive is suppose to help and you get tricked into thinking it really does help. Carb cleaner if your carb is dirty or a stabilizer if you are going to store gasoline for 3 years or more. Gasoline will normally stay fresh for at least 2 years given it is kept cool and dry.
09-05-2012, 12:59 AM
Subaru upper engine cleaner.
09-05-2012, 01:58 AM
RI
If your engine is on the edge something like Klotz will help no doubt, but race gas even at 50/50 is the better alternative. I have experimented with Toluene and that also works. It can be expensive though.
Lou
Lou
09-05-2012, 02:43 AM
I ran 110 leaded octane racing gas in my Cobra and mixed it with the junk they sell at the pump for years with no problems. I buy it in 55 gallon barrels and it really doesn't cost that much more now than the junk I get at the pump. I was running 11.5 compression and raced the car hard. I have never used an octane booster that did anything but cost money. A barrel of racing gas will last you for quite a long time if you mix it. When racing I ran it straight and normally would use two barrels a year.
Lou
09-05-2012, 04:52 AM
I would agree with the guys about mixing with a racing full. Most 110 octane will be a leaded product. The Chevron Traq Tech III would be the best. Lowest price at $430 a 55 gallon barrel in Texas. Chevron still mixes and tests their own product and I don't believe they add color. VP is about $445 a barrel (which I race with), but they buy the petroleum products elsewhere and mix themselves. Only issue is the purple dye they mix in can get messy/goopy if you don't run often. Then Sonoco 110 ($450) is good and mixes well with 91 pump gas for racing (Denver) and not much dye, if any. We blend 50/50 when racing at high altitude, and it cleans the crap out of everything.
I know little about the unleaded fuels from the 3 producers, but know guys who add and mix in their race cars.
Steve S
F-250 w/ 6.4 Diesel
09-05-2012, 05:48 AM
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I agree with Klotz being somewhat helpful. Put mine right on the money if you ask me. I add a whole can when I fill up. 16 oz Klotz to about 10-12 gallons of fuel.
It also stabilizes ethanol enriched gas and acts as a fuel preservative for storage.
Besides, it smells really good coming out of the sidepipes!!!!!
09-05-2012, 06:47 AM
VA
My Roush 427R tends to run on when I switch the key off. This running 93 octane and 34 degree total advance. Adding 3 gallons or so of 110 octane to a 17.5 gallon tank of fuel corrects the issue. Non scientific, real world results. FWIW.
09-05-2012, 09:29 AM
My KCR 427W has 612 hp, & a pretty snotty cam in it. I always run premium (91 octane in Cali) but occasionally have problems with dieseling (run-on). I dump a bottle of the cheapest octane boost I can find (typically Gumout octane boost at Walmart) with each fillup... seems to help. I don't expect any performance enhancement, but it does seem to help with the dieseling in hot weather. I realize it may be purely psychological, which is why I don't invest a whole lost of money in it.
R. Smith
Santa Clarita, CA
09-05-2012, 11:08 AM
I wish more people were as smart as you. Everything you posted is 100% accurate. All those "octane boosters" are a complete waste of money and most are 99.9% kerosene.
09-05-2012, 11:21 AM
+1
Use either a race gas or tulene......tulene has an octane of 114 and is basically an automotive paint thinner.....when I worked in a body shop we would buy it in 55 gal drums to clean our paint guns and equipement,back then,about a dollar a gallon in bulk.......
I mixed it with 93 octane for my race car for years,never had any problems.......
DAVID GAGNARD
09-05-2012, 12:57 PM
RI
It's not a waste of money if it stops dieseling or run on problems, I can attest to this. Look,- good octane booster like Klotz or a Toluene works, if your car is on the edge. Race gas in a 50/50 mix is far better especially if you are way over the edge like Ron said. 11.5:1 is not on the edge. My 10.75:1 on a hot day is,.. and I have used a quality octane booster and/or Toluene to correct some minor issues.
Ron, what kind of fuel did you buy and where did you get it?
Lou
Lou
09-06-2012, 06:05 AM
Lou,
The barrel that I just got was K&S Racing fuel 110 leaded octane. They change brands from time to time as they try to get the lowest priced ones. They also handle 114 leaded octane, but one of the guys told me it didn't improve his car at all over the 110.
I buy it at a distributor here in Redding and they deliver the barrels to my house.
And there is also this that might help.
