1Likes
09-12-2012, 04:34 PM
Cobra Make, Engine: Early Contemporary 427SC w/ '66 427s.o. (car built in '79) by Snow White Rods (Fresno, CA); XKE Series II front/rear suspension (AMP lower A-arms/half shafts), CWI rebuilt IRS, 4-spd Toploader, PS Engineering knock-off rims.
High flowing and loud as I can get it (radical as all hell too)...I like kicking off alarms and not being able to hear anyone when I shut the engine off...hell, I can't hear now anyway due to the "LOUD" music from yesteryears...
George
09-13-2012, 05:37 AM
Cobra Make, Engine: BDR, 302
Originally Posted by rpatton3
I am getting 304 stainless 3" mufflers grafted on my Backdraft's sidepipes. I am also getting a three bolt flange in front of mufflers, just in case I wanted to disturb the peace.
I will be 60 in November and my hearing is still good after lots of shooting guns and open headers in my youth.
I also had new SS mufflers welded in to replace the BDR mufflers. Great sound and freer flowing. I used the 3" ID polished stainless. Great upgrade. The old BDR had a restrictive baffle with two small pipes.
09-13-2012, 10:19 AM
BC
Cobra Make, Engine: CAN-AM cobra, 460 SVO
where did you get the mufflers from? Looking to do the same on mine.
Mark
09-13-2012, 12:19 PM
I got them from Stainless Specialties. http://www.stainless-specialties.com/ Took about 1 1/2 weeks because they were backed up on orders. Great quality and sound. Talk with John.
Although some said 3" ID would be too loud, I think they sound just right. But I have a 302. If you running a bigger motor it may be too loud:
09-13-2012, 02:38 PM
wa
I had the Stainless Specialties on mine with 460 and it was great. But then I'm deaf as a post according to my wife.
John Hall
09-13-2012, 03:00 PM
BC
 i'm gonna be deaf as a post soon John- were yours with the 3 inch core? Which way did the louvers face? Any idea of the muffler length?
Mark
09-13-2012, 03:17 PM
wa
It was the three inch core. Not sure on the louver direction, and they were 24 inches in length.
John Hall
09-13-2012, 03:34 PM
Mine were 27" long not counting the turnout or the 3" inlet pipe. I couldnt really tell the direction of the louvers but I already had the turn outs welded on by SS. But you could easily roll a baseball thru it.
Reason: Add info
09-13-2012, 05:07 PM
BC
thanks gentlemen, I'm thinking 27"+ length with the 3" core, louvers forward, and experiment with putting small spiral inserts into the 3 1/2" tip section like these: Spiral Turbo Specialties:
Mark
09-13-2012, 07:03 PM
SA
My exhaust guy says, if you face the louvres forward, it will burn out the matting inside.?
JD
09-14-2012, 07:52 AM
Active Exhaust 3 - 4 DB
Active Exhaust offers the best of both worlds . Loud as Race Exhaust and Mellow as a Street Exhaust...
Systems for GT40 and 427SC are going to be offered on DPS Products web site (under construction). I have a vid clip of one system. Their system (patend pending) has changes in sound levels 3 - 4 DB. They also retain stock diameter,and vintage looks.
I can send it to anyone that would like to see it.
09-14-2012, 10:21 AM
Wi
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Side Pipes
Lippy:
Order the quietest ones. It seems you re a sensitive kind of guy and wouldnt like the loud ones.
The Nut
Enough is enough. Too much is just right ( C.S )
09-14-2012, 01:41 PM
BC
PM sent!
Mark
09-14-2012, 01:47 PM
BC
JD
IIRC, the stainless specialties ones use a high temp ceramic matting, not fiberglas: can anyone verify?
Mark
09-17-2012, 03:43 PM
Stainless Specialties uses a perforated core not a louvered core like most others, so it doesn't matter which way you install them. The matting is whatever John says it is. I'm not going to cut them open to find out, especially considering what they cost.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
09-17-2012, 03:59 PM
+1 on the loud.
09-17-2012, 05:32 PM
Vic
I'd go the quieter ones... You can always tickle the throttle if you want to be anymore obnoxious to your fellow road users
Enjoy
Cobra Make, Engine: FFR, CHP 427w Streetfignter, Injected Venom.Mass-Flo...550 hp , 550 torq..spec pulley sys..
Lippy
Lippy. I don't know what kind of car you are into but I have a FFR and after awhile, it got too loud for most anyone, enthusiasts included.....they wear out. So, I tried all sorts of 'quiet' solutions and for me, it either didn't do enough or too much, and I didn't want to lose any HP that I paid so dearly for in the beginning. So, I went to Lance Stander in Irvine and asked if he would sell me a set of SPF pipes? They are nice sounding, and just subtle enough to keep the noise acceptable. We had to "mod" them to get them
right but after 20K later, they still work great. Just FWIW.
fred z
Passion......"many things in life will catch your eye....but only a few will catch your heart......follow that one!"
09-17-2012, 08:22 PM
fred z
Thanks, that's good info. Which pipes did you originally have on your FFR, and which SPF pipes did you replace them with?
09-18-2012, 03:43 AM
MI
Cobra Make, Engine: StreetBeasts, 331 Stroker
20K...really? Wow.
