| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
10-04-2012, 11:33 AM
CA
Standard or Wilwood brakes on an ERA?
One of the last options I'm considering on the car ERA is building for me is standard vs. Wilwood brakes. I'm going with the Jag rear end with inboard brakes, and I will use the car almost entirely on the street. I've read all of the posts I could find and understand the standard Camaro-based brakes are very good, with a large swept area, good servicability, and solid braking for a relatively light Cobra. But I'm still considering ERA's Wilwood option for the front only. I also should mention I will use stainless hoses all around.
I'd appreciate your opinions, especially from those who are using the standard brakes on a street-driven car. Are you happy with them, or do you regret not getting the Wilwoods?
Thanks!
10-04-2012, 11:53 AM
AR
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Years ago, George Petrus put outboard discs on Jaguar IRS. His company is cobra racing.com if you want to check. It is big now.
There were no atheists in the foxholes.
10-04-2012, 12:22 PM
AR
Jaguar IRS
Originally Posted by rpatton3
Years ago, George Petrus put outboard discs on Jaguar IRS. His company is cobraacing.com if you want to check. It is big now.
bobraracing.com
10-04-2012, 12:26 PM
AR
cobraracing.com is link. My bifocals and cell phone and sausage fingers could not get it straight.
Lippy, you do not need the big brake option up front.
10-04-2012, 01:11 PM
He's right you don't. But the clanking of the pads in the 100 pound GM calipers will drive you nuts.
Wilwoods = better engineering.
Chas.
10-04-2012, 01:43 PM
CA
Can't I fix that with a hammer and punch, like I fix most things?
10-04-2012, 02:04 PM
Now I am not sure of this, but I think I recall chatting with Peter about the big brakes up front and, at that time, I'm pretty sure that if you upgraded the brakes up front that you also had to upgrade the Jag in-board brakes as well, which ERA no longer does (according to their web site). I didn't put a lot of thought in to it because I was going with the out-board braked rear that already had the larger brakes. BUT, had I gone with the regular Jag rear, and the upgraded Sierras up front (now Wilwood), then upgrading the in-board Jag brakes was the strong recommendation. Peter did not want big brakes up front with the standard Jag brakes on the back. Again, I'm kind of foggy on it all though....
10-04-2012, 02:27 PM
CA
I spoke with Peter. You can do Wilwoods in front and Jag in the rear. But you can't do big brakes in rear with standard in front.
10-04-2012, 02:32 PM
OK, if it was me in your shoes, I wouldn't go with the big brakes right now as I know you're watching the pennies. If the rattling really bugs you (and I don't know if Chas is just pulling your leg on that or not), then doing the upgrade is not that hard. Here are the instructions for the big brake conversion: http://www.erareplicas.com/427man/br...conversion.pdf
10-04-2012, 04:37 PM
CT
You can eliminate any clunking from the GM pads quite easily. Just bend the tabs on the pads so that they are tight on the caliper. Also, we use pad anti-squeal goo on the back of the pads.
10-04-2012, 04:57 PM
Originally Posted by strictlypersonl
You can eliminate any clunking from the GM pads quite easily. Also, we use pad anti-squeal goo on the back of the pads.
Now he tells me...
Chas.
10-04-2012, 05:12 PM
Now he tells me...
Dang, Chas... a pair of pliers and some magic goo could of saved you a couple of grand.
10-04-2012, 05:24 PM
It wasn't the noise I changed them for....
Chas.
10-04-2012, 07:21 PM
If it is upgraded front and rears, for $1100, I would do it in a heartbeat. Heck, I would do it for nothing else than looks.
10-04-2012, 08:18 PM
It ain't. It just upgrades the fronts only to four piston jobs. If you want the backs upgraded you gotta spring for the out-board braked rear.
Reason: dumbness
10-04-2012, 09:24 PM
OK
Cobra Make, Engine: ERA 2137, KC Racing 306
I have been very happy with the standard brakes on my street driven ERA. No noise, great stopping power, very little pedal effort. I wouldn't bother with the upgrade brakes.
10-04-2012, 09:27 PM
CA
Thanks. Exactly what I'm looking for.
| Thread Tools |
| Display Modes |
Hybrid Mode
