Like Tree4Likes
Old 10-23-2012, 01:07 PM
DanEC's Avatar
Originally Posted by Green Hornet View Post
I have been through several exhaust systems on ERA 669. What I have found that works the best are the Mega Oval Mufflers from Stainless Specialities. They were very helpful and agreed to make me a set with an offset 2.5" inlet and a center 2.5"outlet. The mufflers measure 6.5" X 2.5" X 18" which fits between the rails perfectly with no modifications. I have fabricated headers and 2.5" over the axel pipes. All of it is ceramic coated in black which looks great and semi original. The mufflers sound great! Not too quiet, not too loud, Just a deep healthy tone.
I would be interested in seeing some posted pictures of your setup and the tailpipe routing in the wheel wells. I have mine all fabricated but I'm waiting for the ceramic coating to be completed before I can install them. What wheels and tires are you running on the back?
Old 12-10-2012, 07:51 PM
427 Street's Avatar
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
Almost done....just need to have them ceramic coated. I went with a 3.5" outer body/2.5" inner bullet-style muffler from CCE. They are the unpacked glass-pack style muffler. It gives the tone of an older glass-pack.
If you remember, I had 2.5" pipes going into 2" mufflers. After installing the 2.5 mufflers, the car runs completely different. It felt like the car took a deep breath when I first drove it....so much smoother.
Tone? Well, the owner of the custom exhaust shop said, "It is too loud for me, but I like them quieter the older I get." His daughter works at the shop, and said, "I think it sounds amazing....very mean".
Another friend said, "it sounds like a Cobra should...aggressive and menacing."
It definitely turns heads and gets a lot of waves and thumbs up. I will take some pictures of the new set-up. He made the length and position of the pipes perfect at the rear.
I think the car sounds nearly identical to Colin's narrow-hip car. Colin said that his car has glass-packed mufflers that were installed in 1969. When he told me that, I knew I wanted that older/worn-out/free flowing glass pack tone.:
1965 Shelby 427 Street Cobra: CSX3134 - YouTube
"Some things get meaner as they get older."
Old 12-11-2012, 05:09 AM
DanEC's Avatar
Having grown up in the 60s I do have a fondness for the old glass pack mufflers from that era. Thrush glass packs with the square ends were my favorite back then. Looking forward to a sound clip.
Old 12-11-2012, 06:11 AM
mdross1's Avatar
Wow! CSX 3134 is beautiful and love hearing the exhaust side by side.Our car has a similiar growl.Personally and I emphasize personally, love the lines on a Cobra without the lump of exhaust hanging off the sides.
427 Street likes this.
Old 12-11-2012, 07:33 AM
427 Street's Avatar
My first attempt at a You Tube Video. The car sounds much better in person and even better when you are driving in it. I hope you like it. It is very deep and throaty...my cheap video camera makes it a bit raspy sounding. I may have been too close to the pipes.
1966 ERA 427 Street Cobra - YouTube
Old 10-23-2012, 04:30 PM
thanks Dan EC
wondered if that was the case with ERA floors. My mufflers are Edelbroch SDT, chambered with no packing. they sound good, not too loud and quite throaty. centre inlet, offset outlet. my mufflers only hang below the rails about 1/2", so you hardly notice them. consequently, they are close to the floor pan as stated.
I will look into something like the lizard skin as a secondary measure. I have the ACL shield in place above the muffler, although it is mounted 2mm below the floor for an air gap, which leaves about 6-10mm between muffler and heat shield. how far from the floor pan is the top of your muffler??
cheers
Old 10-23-2012, 04:47 PM
Cobra Make, Engine: ERA 428 PI
Hi Dan,
I have the Sunburst wheels with the smaller size Goodyear billboards on the rear. I also have the longer control arms and half shafts so we may be apples and oranges. I will post some pictures as soon as I can.
Old 10-23-2012, 06:15 PM
DanEC's Avatar
Hi Dan,
That sounds like a nice combination. I considered the longer half shafts but ended up going with SC wheels and a little narrower tire instead. I can see how you didn't have any major problem with 2-1/2 inch tailpipes.
Thanks
Old 10-23-2012, 06:25 PM
DanEC's Avatar
Originally Posted by ollykiwi3 View Post
thanks Dan EC
cheers
I'm still waiting for some of my stuff to come back from the ceramic plating shop. Because my mufflers are only 3 inch thick and that I have to keep the exhaust pipes down below the ERA outriggers from the main frame tube to the rocker panel tube, I believe I have about 1 inch clearance to the floor from memory. Also from memory of my mock up I think the bottom of my mufflers are somewhere around 1/2 inch below the frame rail - I don't have an exact measurement. I think the Lizard Skin on the underside of the floors would be a benefit in your case. LizardSkin® Spray-On Insulation : Lizardskin
Old 10-24-2012, 12:43 AM
dan
thanks for info on your setup. gives me an idea of what to expect.although the two are a bit different in setup and clearances.
thanks
Old 10-24-2012, 03:32 PM
Cobra Make, Engine: Contemporary 502 Chev
I have a Contemporary with 3" out of the collectors through 3" Flowmasters up and over the rear with 3" stainless tips. No headaches or burnt legs. I built the car in 1982 with a big block Chevy.
Old 10-27-2012, 06:14 PM
427 Street's Avatar
Neutral
I'll try to get some pictures up tomorrow of my current Dynomax system.
Old 10-27-2012, 08:06 PM
racco's Avatar
great looking car.
I just went through the same process on a 427 so ccx, I used cast iron manifolds and
full tail pipes.
I have photos but they take forever to load.
Old 10-28-2012, 08:54 AM
427 Street's Avatar
Some side shots...I took some close ups of the pipes/muffler with my other camera. I will post them as soon as I download them. The muffler is currently 3.75" thick and 14" long:
Old 10-29-2012, 08:27 AM
Hi 427 Street!
Awesome car!!!
Old 10-31-2012, 09:51 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
A few pics of my Street Roadster undercar exhaust as I was putting it together.
My car is an NAF and I'm running a 351C with Edelbrock Al heads and a custom made 2X4bbl carb set-up.
2 1/2" Polished 304 SS from headers to exhaust tips.
Tucked along side frame rails, over the rear axle to muffler under rear quarter panel and tips out past rear bumper.
Mufflers are Stainless Specialties (I need to polish them yet) 4"OD and 2 1/2" inlet/outlet.
Blue tape where the cut and mitered pieces were to be welded.
Also a pic of my ceramic coated headers (Schoenfeld IMCA headers that come of the heads horizontally instaed of pointing down so I had no frame clearance problems) and SS down pipe.
Greg
Old 10-31-2012, 10:29 AM
DanEC's Avatar
I wonder if anyone has come up with an aftermarket shorty header for an FE that will fit in an ERA? I suspect not, but maybe. . .
Old 11-01-2012, 02:12 PM
427 Street's Avatar
I went to a custom exhaust shop today. Since my mufflers are already hanging below the outriggers, he said that I can put any muffler in there.
He was a hardcore hot rodder, and his shop logo is a Cobra, which I thought was pretty cool. AND, his name is James Dean. He really knows his stuff, and he is one of those older hot rodders that you hope never retires.
He recommended the 18" Magnaflow oval muffler with 2.5" inlet/outlet. He also said that he can run it out the back and not be limited to side exiting pipes. I kinda like the side exiting but he said we can always change that later.
I think a tubular/glasspack shaped muffler will look better, and I was thinking of the Chambered Classics. Eric said he can make them any length and diameter.
Thoughts? Magnaflow? Has anyone heard the Chambered Classics?
Thanks.
Old 11-01-2012, 05:28 PM
mickmate's Avatar
That's the Classic Chambered. I wonder how these would fit Search Results : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
http://www.actoncustom.com/
Old 11-02-2012, 04:16 AM
DanEC's Avatar
These undercar headers look pretty nice Nick. A viable option. I guess they clear underbody pedal boxes like ERA (and others) have? If I didn't already have my ERA headers coated and ready to go I would have considered those. Nothing wrong with the ERA headers however, the individual header pipes make clearances for installaion fairly simple.
Display Modes
