Old 10-25-2012, 12:41 PM
dcdoug's Avatar
Default Pre-bent rubber fuel hose
I have a fairly sharp bend from my fuel log up through my turkey pan to my carb which is causing the fuel hose to kink somewhat. Where can I find 5/16 rubber fuel hose with a 45 or 90 degree pre-bend in the hose?
www.partskeeper.com
Old 10-25-2012, 02:40 PM
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default hose
Why does the bend have to be rubber?
Bend a piece of metal tubing and splice in with rubber hose and clamps.
The Nut
Enough is enough. Too much is just right ( C.S )
Old 10-25-2012, 02:50 PM
dcdoug's Avatar
The Nut
My car is pretty period correct and I'd like to maintain that as much as possible. Right now I actually have the right "gas gas gas" type fuel hoses on there and I guess I could bend the fuel log tabs and accomplish the same thing, but I am worried about breaking them and it's an NOS fuel log, so I'd rather not do that. This seemed like a pretty easy compromise and I was told these pre-bent fuel hoses existed, but can't find them anywhere (which might mean they don't actually exist).
www.partskeeper.com
Old 10-25-2012, 03:44 PM
Frank Messina's Avatar
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
I re-worked the opening on mine with a file. Didn't take much and no one will ever notice. Just a thought.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
Old 10-25-2012, 04:00 PM
dcdoug's Avatar
Frank
I'll take another look. I have a 3255 holley and I think the bigger issue was the angle from the fuel log to the fuel inlet. It's quite a bit different on a 3255 than on the 4160 I had on there previously. I don't think it was rubbing on the TP or I would have clearanced it to prevent wearing on the fuel line. But now you've got me thinking about it and I'll have to look.
www.partskeeper.com
Old 10-25-2012, 06:52 PM
mickmate's Avatar
I'd look at Franks suggestion. The TP is full "o" holes to accommodate it all. Just make that one a tad bigger.
mickmate
http://www.actoncustom.com/
Old 10-26-2012, 06:18 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Doug;
If you sweet talk the guys down at your local AutoZoneAdvanceNAPA store they will probably let you cruise around in their hose collection to find the bend and angle hose you need. You may have to cut it down to fit. This has worked for me a few times in the past.
Bill
Old 10-26-2012, 06:43 AM
dcdoug's Avatar
Originally Posted by sllib View Post
Doug;
Bill
I've done this too and think it's a good idea. I was told by a friend that they do sell 5/16 rubber fuel hose that has preformed bends. I thought someone might just know that part number as googling this hasn't been very successful unless I want to move away from rubber, which I don't. I'll try and post some pics this weekend, but he problem isn't the TP, it's the angle from the fuel log to the 3255.
www.partskeeper.com
Old 10-26-2012, 07:01 PM
Roush #1's Avatar
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Is 5/16 inch hose period correct? Just askin'
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
Old 10-26-2012, 07:15 PM
dcdoug's Avatar
Yes. Both the fuel log and carb are correct for original 427 cobras and both have 5/16 hose barbs.
www.partskeeper.com
Old 10-26-2012, 07:31 PM
Suggestion,
Get a piece of 5/16 OD thin wall metal tube bent in the angle that you want or get a piece of tubing and bend it yourself. Slip it inside the rubber hose. The hose should conform to the shape of the bent metal tube. You can cut the tube to just the lengh that you want. If the tube is thin wall enough, it should not constrict the fuel flow.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
