Old 12-13-2012, 02:50 PM
saturnkk's Avatar
Default Steering Wheel Question
I just purchased my first Cobra Replica. It currently has a black Grant sterring wheel with 5 holes. I would like to change it to a more vintage looking wood type wheel...
First, how can I adapt the 5 hole to a 6 or 9?
Second, I'd like a smaller Sterring wheel, perhaps 13-14 inches to save leg room. Does anyone have any good recommendations on where to find one in the US?
Thanks!!!
Old 12-13-2012, 03:16 PM
G-Pete's Avatar
For the first question you need to show the wheel boss -
to the second, go here here are always steering wheels for sale...
For Sale: FFR Wood Steering Wheel - FFCars.com : Factory Five Racing Discussion Forum
DRB GT40 MK1 red #49- sold
SPF 2063
Old 12-13-2012, 03:30 PM
saturnkk's Avatar
Here it is...
Old 12-13-2012, 04:06 PM
DanEC's Avatar
Originally Posted by saturnkk View Post
Here it is...
I can see why you want to change it.
Old 12-13-2012, 06:22 PM
saturnkk's Avatar
So can I replace it with something like this? If so, what adapter do I need?!?
Old 12-14-2012, 02:47 AM
Ron61's Avatar
Post
You should be able to take the car to an automotive store that sells them and they can fix you up. That is what we did with a friends Cobra that had a wheel somewhat like yours but not quite as bad. One of the parts men came out, took the wheel off and took it in back and in about 2o minutes we were on our way with the new wood steering wheel and I think it was the 15" model..
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 12-14-2012, 03:28 AM
mickmate's Avatar
What steering column/spline do you have? The boss can get matched to that.
mickmate
http://www.actoncustom.com/
Old 12-14-2012, 08:34 AM
G-Pete's Avatar
Here it is...
What I meant to show the boos - what is underneath the steering wheel. From there I can tell you if it's possible.
Here is my adapter from a 3 bolt to a 6 bolt pattern.
SPF 2063
Old 12-14-2012, 09:50 AM
saturnkk's Avatar
Thanks.
Here is the steering wheel off.
Old 12-14-2012, 10:05 AM
LMH's Avatar
LMH LMH is offline
Looks like a GM column. You'll need a hub to fit those splines.
Alba gu brąth
Old 12-14-2012, 10:17 AM
saturnkk's Avatar
Thanks, very new at this. So, any 6 hole hub (for a six hole mount wheel) will work?
I need:
1. 3 to 6 hole hub
2. 13-14 inch sterring wheel
3. Cobra center cap for wheel
anything else?
Thanks again!
Old 12-14-2012, 11:11 AM
saturnkk's Avatar
Any guidance on exactly what I need to buy and where to get it is GREATLY appreciated!!!
Thanks!!
Old 12-14-2012, 03:43 PM
mickmate's Avatar
That large nut in the center holds the steering wheel boss on. If you loosen (don't remove) that nut you will need a puller to get it off. You could also bolt the steering wheel back on, pull it up really hard and evenly and at the same time have someone (you trust) smack the shaft with a BFH and a brass punch. If you can get that loose remove the nut and you will see the splines underneath. Count them and measure the OD of them. A steering boss like this Moto-Lita, the Classic British Steering Wheel is readily available for common splines. As Larry said looks like a GM.
There are some options on 14" wheels here Moto-Lita, the Classic British Steering Wheel
I am a Moto-Lita dealer so if you need anything from their you could let me know or contact them directly.
mickmate
Old 12-14-2012, 04:28 PM
LMH's Avatar
LMH LMH is offline
Don't forget to order a center cap too.
Alba gu brąth
Old 12-14-2012, 05:08 PM
While you're at it, you might as well slap on a quick release hub. Working under the dash is much easier with the steering wheel removed. And "adjusting" the steering wheel so you can see the gauges you want to see, and so they're not blocked by the wheel spokes, is really easy when you have a quick release hub.
Old 12-14-2012, 05:55 PM
saturnkk's Avatar
Okay, here is my assembly from Grant's webpage. I assume I need to remove everything to the steering column?
Is the spline around the post in the center of the steering column then?
Is what you are calling the boss the same as the GT Adapter, post cover AND the adapter hub (together) in this diagram?
Thanks in advance!
Old 12-14-2012, 06:03 PM
saturnkk's Avatar
Can't seem to upload the jpg... it keeps failing.
Here is the link
http://grantproducts.com/files/instr...524-00-01a.pdf
Old 12-14-2012, 06:24 PM
saturnkk's Avatar
Could I simply use this Grant to Momo adapter?!?
Old 12-14-2012, 08:05 PM
LMH's Avatar
LMH LMH is offline
You would have to find out if the bolt circle is the same on whatever wheel you want to use and the adapter. I kind of doubt the bolt circles on the hubs are standard.
Normally you would use a wheel you like and their hub together. Most of us use Moto-Lita wheels as that's what original cars used. Original size was 16" but 15" is common in the replica world. Smaller than that gets a little strange looking IMO.
Alba gu brąth
Old 12-15-2012, 06:21 AM
mickmate's Avatar
I would start with the wheel you want to look at and hold and work your way in, you can make anything fit. Find what works for a diameter and dish, figure it out from there. I don't think quick release wheels are street legal in many places, they are race car stuff.
mickmate
