Old 03-21-2013, 02:08 PM
Unique580hp's Avatar
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
Default Thank you.
Thank you for all the help on the 427 question.
You all were wonderful.
Scott
1st car was a Cobra, hopefully my last will be also!
Old 03-21-2013, 02:26 PM
Bernica's Avatar
Senior CC Premier Member
Welcome. Folks here help each other and don't charge consulting fees for advice, or I would have been broke years ago. Just get pics of the motor and give the casting numbers (block and heads). Somebody will help. Do you know where the casting number on the block is?
Old 03-21-2013, 02:41 PM
philminotti's Avatar
Screw in freeze plugs and cross bolted block is a great start...a photo of the driver's side would clinch it. If it has the side-oiler gallery "hump" running just above the crossbolts, you've got yourself the real deal
Phil
Old 03-21-2013, 02:49 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
The marine engines have the side oiler passage on the side of the block and are typically not side oilers.
I say you need to see factory screw in freeze plugs and the plugs in the side oiler passage that show it was drilled. They are visible on the back of the block.
Old 03-21-2013, 02:50 PM
roadrod2000's Avatar
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
The casting number C7AE-A translates to a 427 side oiler, looks like the real deal
Rod
Old 03-21-2013, 02:54 PM
FWB's Avatar
FWB FWB is offline
yep a pic of the other side would be helpful., looks like a leaky plug there on the passenger side. it has the right casting number for one. C7AE-A
Fred B
Old 03-21-2013, 03:10 PM
The photo is of the driver's side, and the block is upside down. Look at the bulge along the length of the block 2" below the oil pan rail. It has 3 hex plugs screwed in it. That's the primary characteristic of the side-oiler block.
Old 03-21-2013, 03:17 PM
Bernica's Avatar
Yep, that's a good number according to my books. Here is what I have....Hope it helps and good luck.
Old 03-21-2013, 03:45 PM
Bernica's Avatar
Sorry, but this site is running really slow right now for some reason. Here is the attachment. All I could find and hope it helps.
Old 03-21-2013, 05:21 PM
Default Thank you!
Thank you all for the help. I really appreciate it.
A fellow Club Cobra member named Steve talked with me about an hour on the phone and walked me through the whole process and where to look for numbers etc.
Thank you, thank you, thank you.
Now I hope that I can get there in time to buy it.....lol.
I'll post photos if I do.
Have a great day.
Scott....aka Unique580hp
