Old 04-23-2013, 05:39 PM
Cobra Make, Engine: era 427 side oiler
Question 427 block numbers???
aside from the casting date and the block i.d.info, are there any other letters
or numbers (such as a serial no.) on a 68 427 block? thanks gary.
Old 04-23-2013, 06:15 PM
FWB's Avatar
FWB FWB is offline
the date code by the oil filter adapter, some had a block casting number some did not. and that's about it to identify it.....
427 in the lifter valley.....um......screw in freeze plugs.....
why? do you have something your not sure of?..... or looking at one?
Fred B
Old 04-23-2013, 06:45 PM
Question
no, i'm quite sure of the motor i have. got a letter from n.y. state wanting to inspect my car for stolen parts. just trying to figure out how they would know if it was or not!
Old 04-23-2013, 07:25 PM
FWB's Avatar
FWB FWB is offline
careful they may have GM'itis, GM put vins on blocks, ford did not.
gather up your receipts you have to prove it i guess......what do they do if you can't show a trace for the motor? repossess it?
so you can't buy a large soda and you need to prove the motor isn't stolen..
how do you prove a negative?......
Fred B
Old 04-24-2013, 10:04 AM
legenmetals's Avatar
Default block numbers
Here are some pictures of my 1966 427 block. I hope they help.
Old 04-24-2013, 10:12 AM
Unhappy
from what i have heard from others, yes they can take your motor. bought the car in conn. have paper work for the car but not individual parts(motor, trans. ect) i don't like the sound of this. anyone else had this problem?
Old 04-27-2013, 08:38 AM
Cobra Make, Engine: TBD, other is 67 Mustang GTA 390 Convertible w/air,
Send a message via Skype™ to fostereast
Default 427 Block
As far as I know the 427 blocks cast for aftermarket by Ford use did not or might not have "casting" numbers on them, just the date code casting. I've had two '73 blocks that do not have casting numbers. I don't know what year was the last year for production usage of the 427.
Old 04-27-2013, 10:13 AM
Bernica's Avatar
Senior CC Premier Member
If that is a C5AE-H as it appears to be in the pic, then it should be a 1965 427 side oiler.
