January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-30-2013, 03:58 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Oval Bezels 1 1/2" anybody
Anybody know somebody who sells oval 1 1/2" bezels, any vendors around ?
Old 04-30-2013, 05:17 PM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Are you interested in using them, say to cover roll bar holes? If so, you might consider looking at a electrical supply house. They carry products called "KO seals" or knock out seals. Wich are used to re-seal holes made in electrical panels. The higher quality seals come with threaded bolts welded to the center of the under side of the seal with a backing piece that sandwiches the two halves together & a wingnut; a gasket is also included. Be sure to say that you want stainless steel KO seals. These come in brushed stainless and are machine tappered on the top side & look great. Or they could be painted. They come in sizes from 1/2" to 4" Some electrical supply houses also offer the same style in mild steel. Grouse-Hinds is one brand, that makes this style.
Old 04-30-2013, 07:55 PM
I'll check them out,thanks
Old 04-30-2013, 08:21 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Russ's Roadster Shop. MK3 Roadster Shop at RT's Custom Cobra Car Parts
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 05-01-2013, 12:55 AM
Cobra Make, Engine: FFR MK IV/Coyote/PS/PB/ABS/AC
Check with Breeze. I recall they were going to make them for the FFR 1-1/2" FFR bars.
Display Modes
