Like Tree1Likes
Old 05-15-2013, 03:16 AM
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Thumbs up So How Fat Are You?
Why is it that so few AC Cobra replica turn key or kit builders ever mention there GVW? I know that with a glass body & heaver duty frames, the replicas produced since the originals are on average 200 to 600 lbs. heaver. I remember that csx 3116 with 427 cid iron block/heads was about 2,350 lbs. Csx 2058 with 260 cid iron block/heads was not quite 2,100lbs. My ERA 427S/C w/427 iron is 2,639 lbs. I know that FFR's tend to be in the low 2,200 lbs. range with a SB. So how fat is a glass/alum. CSX 4000+, a KMC, SPF, Unique, etc. So big block or small block; iron or alum. How fat are you?? Come on, get on those scales!
Old 05-15-2013, 05:09 AM
mdross1's Avatar
As soon as I saw this thread title looked down at my beltline ha ha.Had our car scaled a few years back to get a grip on why it handled so poorly.It is a CMC 460 powered car and then had cast iron heads, intake,water pump and flywheel.(now all replaced with aluminum including 9" center section) it then weighed near 3000lb.Now down around 2750. The organic part we don't need to know about.Any frost on the pumpkin this morning Silversmith?
Old 05-15-2013, 06:06 AM
2550 pounds with me out of the car. Add another 190 with me in it.
Old 05-15-2013, 07:14 AM
Dwight's Avatar
Smile
Lone Star 94" wheel base 2315, no gas, no driver.
Dwight
Old 05-15-2013, 08:47 AM
dcdoug's Avatar
CSX 6022 (glass car) is about 2,600 lbs without me in it. I think there was about 12 gallons of gas in it. My engine was an NOS 427 FE build, iron block, iron MR heads, lemans rods, TRW pistons, etc and is pretty true to what was in the originals. I also have billboards, so tires are bias ply and comparable too. Biggest difference is probably the TKO, which probably adds a few lbs. Lakewood bell might have added a few lbs too (will be changed to a QT shortly).
www.partskeeper.com
Old 05-15-2013, 09:00 AM
Originally Posted by dcdoug View Post
.. the TKO, which probably adds a few lbs. Lakewood bell might have added a few lbs too...
My new cool Xtreme top shaves a pound and a half off.
Old 05-15-2013, 09:15 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Hurricane 1st gen.
KCR 482, iron block, aluminum heads, straight axle, C-4.
14 gallons of fuel, 2,370 lbs without me in it. Too much with me in it......
Dan
Old 05-15-2013, 09:50 AM
GT350Mike's Avatar
Cobra Make, Engine: CSX6363
Can't remember if it was Dwight or someone else, but they said the CSXs ran north of 2500lbs. I knew my car was heavy but daaaaaaamn, 2600lbs is w/in 200lbs of my 66 Mustang. The only difference between Doug's set-up and mine are the aluminum heads and QT bell housing, which might save 30-40lbs at best.
I know where I can save about 15lbs, but that would require time in the gym, better diet, and drink lite beer in lieu of the heavier beers..........ain't gonna happen.
Old 05-15-2013, 12:04 PM
Default A&c
My A&C with iron FE, full Tank and me ...2658
Jon
Old 05-15-2013, 01:43 PM
itstock's Avatar
Gold Star Contributor
2609 with me in it, with 5/8th of a tank of gas. So 2434 without me. It's a backdraft racing with a small block. Still needs to get the corner weights right.
Old 05-15-2013, 02:02 PM
FWB's Avatar
FWB FWB is offline
ok, I will probably be the head fat boy...
3250 with my 150 lb body in it and 6 gal of gas.......
Fred B
Old 05-15-2013, 02:06 PM
JimH's Avatar
Cobra Make, Engine: F5 stock 302 EFI
2320 lbs. w/ 1/2 tank of gas, without me, Factory Five complete kit, stock EFI 5.0 engine ,T5 trans, double roll bars, sidepipe shields, 245/315 Nitto 555 tires.
Old 05-15-2013, 04:49 PM
Nice paint job on that K&N top Pat! I may have to do same on mine. The 2,600 or so on my ERA was with out me in it & a 1/2 tank of fuel. Over 2,800 with me in it. Oh the Shame! But I do love a good Rocky road ice cream after a spirted romp. At least my balance is 50.7% front & 50.3% rear. Left/right is 50/50
Old 05-15-2013, 04:56 PM
RodKnock and I could get you in shape using nothing but a speed rope.
Old 05-15-2013, 04:58 PM
What if, in theory only, you replace the big v8, with a worked, turbocharged rotary engine. Would it outhandle or perform any better?
JD
Old 05-15-2013, 05:30 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
That's just wrong.
Old 05-15-2013, 07:50 PM
FWB's Avatar
FWB FWB is offline
JD
it may very well.....but i don't think i could set off all the car alarms on my street as i rumble by..
Jaydee likes this.
Fred B
Old 05-15-2013, 11:04 PM
dcdoug's Avatar
JD
How to emasculate a cobra in one "easy" step......
www.partskeeper.com
Old 05-16-2013, 12:23 AM
Magnum 427 SF from UK, small block, kevlar body, empty 2134 :-)
Old 05-16-2013, 04:29 AM
I have a light space frame that I built for a Cobra project. It's set up for C5 Corvette suspension, LS engine, and T56 Transmission. I also have a lightweight Cobra body. Based on the weights of similar cars that I have built I think it's possible to finish the Cobra out at around 1850 lbs.
My self built Speedster has a 104.5 inch wheel base. It has a pretty heavy body and weighs, on my race scales, wet, 1980lbs. I have a T bucket inspired body for it. With the Tbucket body it weighs 1840lbs. I can change the body in under an hour.
I just weighed my current project. I built a space frame to which Miata parts bolt to. It has a 95 inch wheelbase and is using a Devin body that I am modifying. It will be under 1500 lbs when completed. The chassis with drive train weighs 1080lbs.
Just finished breakfast. Going to the shop to work on it. Having fun.
I like light cars. I don't know why. Because when I sit my 240lbs down it changes everything!
