Old 07-30-2013, 06:20 PM
Default Interested in adapter/spinner retainer clips??
We finally have our adapter/spindle spinner retainer clips .
Unlike "diaper clip" versions these will work with hub end caps in place and have a race car design.
Stainless spring steel and easy to install ,link below.
1 x set adapter/spindle safety clips : Vintage Wheels, Hot Rod and Muscle car
If above link does not work please go to:
vintagewheelsus.com select adapters etc from the menu
Bob at Vintage Wheels
Old 07-31-2013, 02:40 PM
Looks good - presume these will work with others e.g. trigos?
how much is shipping to the uk for 1 set, and 5 sets?
pm me if easier,
thanks,kevin
Crendon 427, in the making
http://crendonreplicas.com/
Old 07-31-2013, 04:07 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Great product Bob. What is your recommendation for drilling the hole location:
Tighten the spinner and drill so the pin is snug up against the spinner?
Drill the hole one thread pitch away so you can see if the spinner has moved/loosened?
Greg
Old 07-31-2013, 04:31 PM
Hi Greg
drill close to the spinner but leave a slight clearance to make it easier to insert the pin. These clips are fail safe rather than locking devises ,so make sure wheel is tightened with a lead hammer , mark the wheel and spinner to check for movement or safety wire.
Full instructions are included with the clips.
Bob 1619 952 4717
Old 07-31-2013, 04:35 PM
Hi Kevin
postage to UK 1 or 5 sets same cost - first class $15 or priority $25 with tracking.
Will work on Trigos and most adapters or similar thread diameter.
Bob
Old 08-01-2013, 06:20 AM
SPF1061's Avatar
Cobra Make, Engine: Superformance Mk III / Windsor platform
Those clips look very nice. How the heck does one go about drilling the holes?
Old 08-02-2013, 09:21 AM
SPF1061
With the wheel off you should be able to drill 1/8 holes your adapter ,making sure you mark carefully and the holes are 180 degree apart.
Easiest is to remove adapter and use drill press.
Bob 619 952 4717
