Old 09-10-2013, 04:38 PM
mtrain2000's Avatar
Cobra Make, Engine: Shell Valley
Default Can someone give the measurements of the oil cooler?
I'm speaking of the oil cooler that mounts in front of the radiator behind the lower air intake hole.
I'm going to build my own setup so it would be nice to have some know dimensions vs trial/ error........thanks.
You can put a chebby engine into a Ford body, but it will NEVER be a chevrolet. It also shows you're ignorant, and lack imagination, as in its been done to death as in its not an original idea.
Old 09-10-2013, 04:49 PM
mickmate's Avatar
Usually 13" across the mounting tabs and a common core height is 5.78" although there are all kinds of height options.
mickmate
http://www.actoncustom.com/
Old 09-11-2013, 12:40 PM
mtrain2000's Avatar
Ok, thanks Mick.
Old 09-11-2013, 02:36 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
427 or a 289??
Old 09-11-2013, 03:05 PM
mickmate's Avatar
Dimensions are here for 427 style.
BAT, Inc. - MOCAL Oil Coolers
Comp Classics has the wide short 289 ones.
mickmate
Old 09-12-2013, 07:48 AM
If you still need measurements. Check the cobra, nardi, moto-lita, mini cooper, ferrari, shifter carts, parts and accessories from Finish Line and I should have measurements listed. If not call me and I will measure for. I have Mocal oil cooler. Its the original oil cooler for the cobra.
Jackie
jackieriobe@gmail.com
954 436 9101
Old 09-12-2013, 07:16 PM
Sorry, what I meant was, is this for a 289 or a 427 installation?
Old 09-13-2013, 05:45 AM
Oil cooler measurements are Bracket 13"x2" hieght 4 1/2"
Used on sc corba 427
hope this helps,
Jackie
Finishline
