Old 11-11-2013, 11:13 AM
Double Venom's Avatar
Guilty for not reading all the post, 99%, but has he ever found the real culprit yet?
Sorry if it's in the thread and i missed it.
DV
Old 11-13-2013, 01:47 AM
PANAVIA's Avatar
Fuel filter in backwards >? -- or Unvented tank as others have stated.
Old 11-13-2013, 05:39 AM
Dwight's Avatar
Smile
one of our buddies burn up a coil, we replaced it and soon a MSD bad when bad, then a magnetic pick up, second magnetic pick up before we had the alternator checked. Had it rebuild and solved all the problems.
Dwight
oil filled coil laying on their side will fail. Air pocket inside will allow damage to the wire coil. Some will total fail while others will work after they cool for a short period.
Old 11-13-2013, 07:31 AM
Was the Alternator putting out too much voltage? I just replaced my MSD pickup,coil,and box.I would hate to have it all go bad again because of the Alternator.
Old 11-13-2013, 12:26 PM
Dwight's Avatar
Smile
I think it was over charging. That was 2 or 3 years ago and I'm old. Nuff said
Dwight
Old 11-13-2013, 12:43 PM
Dwight's Avatar
Smile
Marc Wulf, you can check with a volt meter at the battery. Take a reading at the battery and then crank the car and check again. You should get a 13 to 14 volt reading with the motor running.
Dwight
Display Modes
