Like Tree2Likes
  #21 (permalink)
Old 03-05-2014, 01:54 PM
Once the pipes get hot enough, they will "relax" a bit so that it's somewhat easier to remove and refit.
  #22 (permalink)
Old 03-11-2014, 09:43 AM
Well, I tried to remove my driver's sidepipe last night - the one that was a bear to get on. Since this is the one that has a ding on it and I was going to have the Wideband bung welded onto it and recoat the whole thing. I removed the front wheel and wheelwell panel, and had my wife help. This sidepipe is not moving. Not a bit. I even used a flat-faced punch placed on the lip of the collector to drive it in-line and off the headers. Nothing. This thing appears to be on for good, short of cutting it off. I ended up putting it all back together rather than beating the daylights out of it and risk damage to the sidepipe or headers. Now I may have to weld the bung on the passenger sidepipe (I know I can get this one off) - even though it's in perfect condition. Hopefully if I get it TIG welded on the inside and mask and paint the weld with VHT ceramic paint, it won't be noticable.
  #23 (permalink)
Old 03-11-2014, 09:50 AM
DanEC's Avatar
Did you try spraying penetrating oil in the connections? With all of the moment arm resulting from the sidepipe hung on to it - hard to believe that a little twisting down and back up on the end of it wouldn't loosen it up some at the collector.
  #24 (permalink)
Old 03-11-2014, 11:33 AM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Lippy,
Sorry to hear you're having trouble getting that pipe off. One thing I'll emphasize is the importance of moving the back end of the pipe around a lot - not just a little. That should go a long way toward loosening up the slip fit.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
  #25 (permalink)
Old 03-11-2014, 12:26 PM
Thanks for the tips. I'm just very cautious about moving it too much. I don't want to bend the headers or break the welds. Then I'd have a real problem.
Display Modes
