View Poll Results: Which do you prefer classic 15 or modern 18?
Classic is best stick with 15" 61 70.11%
Can't beat the better performance of the 18" 26 29.89%
Voters: 87. You may not vote on this poll
Like Tree11Likes
Old 02-12-2014, 08:50 PM
buddyg's Avatar
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
Default 15" vs 18"
So I'm torn the classic look of the 15's or the better performance of the 18's?
What say ye?
Old 02-12-2014, 09:12 PM
Bill D's Avatar
15" with the large sidewall tires fill the wheel wells and look better, IMO
Old 02-12-2014, 09:13 PM
fordracing65's Avatar
18 for performance, their isn't a tire that comes even close to the best 18's out their for performance, the 15 inch Avon's are great for performance, but put on a skid pad they will get left behind...
PRIDEnJOY
Old 02-12-2014, 09:24 PM
Dimis's Avatar
Buy a set of 15s with Billboards for the look and then a set of 18s for racing around on...
Win/Win.
Me, I'm a 15s original guy, so went with Avons because they are DOT.
Old 02-12-2014, 10:25 PM
WardL's Avatar
I have 17" they look "normal" to me. It is what ever you get used to. No matter what you have, you will like what you have. That is, unless you want to be pissed off all the time..... ha ha ha...
Old 02-12-2014, 11:03 PM
Rick Parker's Avatar
It's all a personal opinion and what You think looks best. For me the 18's are out of scale regardless of their performance advantage. Too much wheel, not enough tire.
Clayboy and Bartruff1 like this.
Old 02-13-2014, 03:09 AM
Chook's Avatar
Cobra Make, Engine: DRB Windsor 302 stroked to 347
15s if your car is more traditional looking, 18s if using for racing performance purposes.
Old 02-13-2014, 04:47 AM
Win/Win.
Best option as you can run race 18s and street 15s. SRs for street and R6/A6 for track/autocross.
Old 02-13-2014, 05:00 AM
buddyg's Avatar
Where is everyone buying their tires?
Old 02-13-2014, 05:19 AM
Tommy's Avatar
Neutral
Here's a thought about tires that I don't recall having seen on this forum. When designing the suspension for a car, engineers consider the contribution of the tires as if they were additional springs. So a car that will run tall sidewall tires with lower air pressure will have more tire spring than a car running short sidewall tires with higher air pressure. I mention this because people who arbitrarily switch tires from what the designer intended are likely affecting both the handling and ride comfort of their cars. ... Admittedly this is neither noticeable nor a problem for most replica Cobra drivers, but it is a consideration for those who put a high value on either maximum performance or maximum comfort.
Silversmith and Detroit Bill like this.
Tommy
Previously owned EM Cobra
Old 02-13-2014, 06:28 AM
blown871's Avatar
Good thread; going to follow it.
I will also be making the leap from 15-18 for multiple reasons.
Going to stick with a wheel that looks as close to what I already have.. as not to draw a lot of attention to the wheel/rim difference.
Old 02-13-2014, 08:41 AM
itstock's Avatar
Gold Star Contributor
I don't get the 18" decision by a lot of different companies. It is the most limited performance tire market compared to 17's and 19's.
Personally, I think the 17's look great on these cars.
WardL likes this.
Old 02-13-2014, 09:47 AM
G-Pete's Avatar
15 inch for street and 18 inch for track, really?
Now watch this video of Bill Shepherds Cobra....
Nurburgring Aug 2010 Cobra incar footage - Bill Shepherd Mustang - YouTube
.....he is running 15 inch. Tell me again about 15/18 street/track again.
Bxx1 likes this.
DRB GT40 MK1 red #49- sold
SPF 2063
Old 02-13-2014, 10:05 AM
Too bad Bill wasn't running 18s, he would have done even better. 15s vs. 18s boils down to a very simple question, do you want original looking wheels on your non-original replica or do you want wheels that optimize performance on your non-original replica. One need look no further that what the exotics are using to see where the performance edge is
Old 02-13-2014, 10:34 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Originally Posted by AL427SBF View Post
do you want original looking . . . on your non-original replica or do you want . . . that optimize performance on your non-original replica. One need look no further that what the exotics are using to see where the performance edge is
Jeez. Don't be so hard on us!
Aren't those gauges you use "original looking"?
They certainly aren't the best gauges you can get and certainly not what the exotics are using.
We ALL ride the fine line, no, make that the FAT line of looks/originality vs performance.
rodneym
Old 02-13-2014, 11:04 AM
... last time I checked gauges didn't improve lateral g's
Old 02-13-2014, 11:24 AM
RodKnock's Avatar
What say ye?
If you go 18's, do they make those chrome hooptie spinners for them?
Old 02-13-2014, 11:27 AM
Default 15 vs 18
You put him on 18" Hoosier A6's with proper camber and spring rates and he would pick up 6 seconds a lap. I ran 15" back when they actually made good slicks for 15's (1970's), LMS 16" slicks in the 1980's and 1990's on wider than stock rims (9.5 F and 11 R) and now 18" on (11" F and 12" R) and I can tell you there is no comparison. Yes, part of it is modern compounding but the steering response is so much more precise with low aspect ratio's I would never go back. There is also the problem of tire distortion under high loads
with large aspect ratios especially with poor suspension geometry. There is a reason that the automobile and tire companies gravitated toward larger wheel diameters, they are better.
Old 02-13-2014, 11:44 AM
jwd's Avatar
jwd jwd is offline
18's on a Cobra look about the same as 26's on a Monte Carlo. Go with 15's for the best look.
Old 02-13-2014, 11:45 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Fair enuff.
rodneym
