February 2026
Old 03-20-2014, 02:59 PM
Ant Ant is offline
Default AN Plumbing adapter fitting ID size
Looking for information on AN adapter fitting ID size, I have a fitting with no brand name on it, -10an O ring boss to -12an male, the ID size is (0.638") -12an all the way through, this makes it quite thin on the boss end but nice for oil gallery adapter or where a reduced size weld bung is needed..
Any practical experience/info on what brands have the largest ID or flow rates?
A J. Newton
The 1960's rocked!
Old 03-20-2014, 04:30 PM
I use mostly Fragola and Aeroquip stuff, much of which is radiused. I've heard XRP has the thinnest walls/largest inner diameters.
Old 03-20-2014, 04:42 PM
Ant Ant is offline
I have heard same re XRP.
I have many $K's of Aeroquip fittings and startlite hose yet to go on to this project its dam hard to keep track of and then with changing parts as I have a habit of, probably will end up with about $1k of surplus. Have kept the hose fittings all AQ, they don't have the greatest range of adapters so have gone with XRP on some things.
A J. Newton
The 1960's rocked!
Old 03-21-2014, 02:29 AM
Cobra Make, Engine: Almac Cobra 427R
If you end up with spares just send them to me!
Old 03-21-2014, 03:29 AM
Ant Ant is offline
The previous owner of your car mentioned he spent $5k on plumbing...
A J. Newton
The 1960's rocked!
Old 03-21-2014, 07:35 AM
Z-linkCobra's Avatar
XRP has some of the best fittings I have used. I have more than a few of their fittings on my car. Call them up and get them to send you a catalog. You wont be disappointed with them.
Make sure of the color of fitting you want. I went the traditional blue and red from earls and all the rest. I am slowly changing out the fittings to either black or plain aluminum. If you want plain aluminum on a fitting you already have you can remove the anodizing with some stuff from eastwood. Works very well.
Gene
Old 03-21-2014, 08:39 AM
Jerry Clayton's Avatar
In the AN world the number replates to 1/16 inch--so in your case the id size .638 is equalate to 10/16 inch or the #10 an size-------
Old 03-21-2014, 01:54 PM
Ant Ant is offline
The measurement I gave is for the ID size of the fitting I think the AN # is to do with the Army Navy thread, not the bore size.
Measured these AQ fittings, -12an O ring boss has 0.600" ID
-12an 90 degree 0.580" ID
Unknown brand -10an o ring to -12 male has bore size of 0.638"
I guess I can buy a 10-12 adapter fitting and lathe out the bore, but I would prefer to have a nice anodised factory fitting..
A J. Newton
The 1960's rocked!
Old 03-21-2014, 04:02 PM
I can believe that. I replaced a good chunk of it as rubber was coming off old lines, and some fittings as they were letting go. That cost me a couple of grand and that was only a small portion.
