Old 06-06-2014, 07:47 PM
Cobra Make, Engine: era 427 side oiler
Question need some help with new clutch slave
installing a new clutch slave in an era. can't get the metal tube out of the slave that comes from the fluid reservoir up top. it appears to be pushed into a rubber gromet on top of the slave. anyone know the trick to getting this little bugger out?
Old 06-07-2014, 04:26 AM
DanEC's Avatar
For some reason I'm not clear what metal tube you are having a problem with. Can you post a picture of it? Is it the BMW model slave cylinder?
Old 06-07-2014, 04:33 AM
I trust that you are talking about the feed line to the BMW master cylinder, not the slave. If it is the slave, you've got a non-standard setup.
The steel feed line has a bulge (basically an un-flattened double flare) that fits into a groove in the master cylinder "in" grommet. It's just pressed in by hand. Nothing permanent.
Old 06-07-2014, 07:02 AM
Thumbs up
thank-you to those who replied, yes bob you are right i meant master cyl, this is what happens when you get old!!!!!! thanks again.
