Old 06-26-2014, 05:26 AM
mnm99's Avatar
Default What material is used on the inner fender liner?
I know Top of the hill sells the precut pieces, I only need a few to patch up the inner fenders. What kind of materials are used in the inner fenders? Where can I find some.
Superformance #467, 351W, Supercharged
Old 06-26-2014, 07:53 AM
Kirkham Brothers.
B. Ewing
Old 06-26-2014, 09:13 AM
mnm99's Avatar
Originally Posted by bret a ewing View Post
Kirkham Brothers.
I suppose you don't know? Anyone?
Old 06-26-2014, 09:19 AM
Just go to a local arts & crafts store and buy 1/8" neoprene sheet. You can find it in small sizes (16x20) and in black. Cut to fit with scissors and use 3M spray adhesive. Then coat over the patchwork with spray bed liner to seal it in. This works and lasts a long time, and won't bleed through the 'glass to the paint.
Old 06-26-2014, 09:50 AM
mnm99's Avatar
I picked up some of this. This should hold right? I'll check my local store. Thanks.
Marine Fast Cure 5200 Adhesive Sealant :3M US
EDIT... Can't find it at my local Arts and crafts stores...
Old 06-26-2014, 12:25 PM
I think the stuff you are planning to use may work, but it also may bleed through. Don't make this any harder than it needs to be. The Super 77 is essentially rubber cement in a spray can. Top coating it with any black bed liner (spray) will seal it in.
Old 06-26-2014, 12:27 PM
Actually, this stuff is easier to find and works just as well:
Any NAPA or well-stocked auto parts store should carry. Or auto paint store.
Old 06-26-2014, 10:40 PM
Rick Parker's Avatar
If it is a Glass car you can spray rubberized aerosol undercoating material onto the under sides of the fenders and it will work quite well.
Old 06-27-2014, 01:16 AM
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
If you use 3M 5200......don't ever plan on removing it! I would characterize it as "permanent"!
Good luck.
P.S. 3M 5200 doesn't like sunlight but that doesn't seem like a consideration where you would use it.
Old 06-27-2014, 05:39 AM
Cobra Make, Engine: BACKDRAFT
Send a message via AIM to SKINNEDR Send a message via Skype™ to SKINNEDR
I have a BDR and it have always cross my mind to add a inner liner to my fender, however have never seen a Cobra with Fender liners..
can anyone post a picture of what that looks like?
Not trying to jack this thread.. If necessary I will post separately..
Old 06-27-2014, 05:40 AM
mnm99's Avatar
Good luck.
That's my plan. If I install the pads again I want to do it once. God forbid something happens to the car and I need body work we'll come to that road when it comes.
I'm still looking local for some neoprene sheets. I can't seem to find them anywhere.
Old 06-27-2014, 09:29 AM
Funky Foam 12" x 18" Black EVA Foam Sheet - 2mm | Shop Hobby Lobby
Sometimes it's listed as "foam", but it's neoprene or like a neoprene. 2mm is plenty. Just seal it in with the spray bed liner. Between the foam/neoprene barrier and the bed liner seal you won't have any issues with rocks starring your exterior. No bleed through. I don't have pics to post but this is a one beer project.
Old 07-07-2014, 12:58 PM
With the 3M™ Marine Fast Cure 5200
Adhesive Sealant, you don't have any issues with it affecting the paint. I heard some sealant will seep through and affect the paint.
where do you purchase it?
Dex..
Old 07-09-2014, 12:14 PM
mnm99's Avatar
Dex..
I ended up using 3M 847 contact cement. no bleed through.
Old 07-15-2014, 11:48 AM
Can anyone post a picture of their finish product?
I'm getting ready to do mine next week..
Old 07-16-2014, 12:47 AM
SKINNEDR-
3M 5200 should be at most any marine/boating supply store. Of course there's always Amazon.
Old 07-30-2014, 09:09 AM
I tried 3M77 and it did not work out well for me. I did both surface and it would not stick well to my satisfaction.
I gave up and took whatever was left, off.. I'm just going to coat it with Bed Liner...
Old 07-30-2014, 01:42 PM
Dwight's Avatar
Smile
good thread
I need to line my fender wheels
Dwight
Old 07-31-2014, 05:50 AM
Cobra Make, Engine: Midstates 351W tremec
I have to do mine as well. Here is where I sourced the rubber.
McMaster-Carr
Old 08-05-2014, 06:04 PM
What I did wa the truck bed spray on liner...
Doing the liner was just too tackie...
