Old 06-26-2014, 04:12 PM
DanEC's Avatar
Default How much air cleaner to hood clearance is enough?
I installed K&E filters (thank you Yugo) in my S&H air cleaners on my FE dual quad set up and measured my clearances with modeling clay. I have a bit over 3/8 inch clearance from the top of the acorn nut to the hood underside on the rear air cleaner. I can change out the acorn nuts for common nuts if I have to.
I think 3/8 inch should be safe - I also have my driver side motor mount through bolted. Haven't started the motor yet. Anyone have issues with underside hood contact with around 3/8 inch nomimal clearance??
Old 06-26-2014, 06:30 PM
You can get a nice stainless nut and grind it down thinner, and you can then get away with 1/4" or a bit less clearance to allow for movement. I've tried it all.
Old 06-26-2014, 06:49 PM
DanEC's Avatar
Lippy - so it sounds like 3/8 inch should be pretty safe? There are always a few variables. I guess I'll watch it closely and change to a SS nut if I see any sign of contact.
Old 06-26-2014, 07:43 PM
Bernica's Avatar
Senior CC Premier Member
Get a Kwik-Latch if you can make it work. We have been selling these as part of the MAXX Air 9" Low Profile air cleaner package through Nick at Acton Custom.
The latches themselves are available here:
Quik-Latch Billet Air Cleaner Housing Mini Latch Part # QL-25-AC
Old 06-26-2014, 08:21 PM
Dimis's Avatar
Hey, those are really cool.
I'm going to pick up a couple of those.
Old 06-26-2014, 09:22 PM
More than enough. You can get away with less if you need to. And those Quick Latches look cool also.
