Old 07-28-2014, 03:24 AM
BAsque1's Avatar
Originally Posted by ERA 778 View Post
OK. That makes sense. A loose ground wire for the MSD box would certainly cause a problem! Mounting the coil upright is the right thing to do. Make sure you drive long enough to get everything really hot under the hood. My problem would sometimes come and go with heat under the hood.
Good luck, but I think you found your problem.
I really think so I am doing one more thing and that is to change all the spark plug wires with MSD wires and see how it behaves.
Tks bud
Lou
Basque1
Old 07-31-2014, 04:46 AM
BAsque1's Avatar
OK guys, here is the latest update and it is a positive one. Changed the spark plug wires with MSD's noticed that one of the old wires had a sign of arching and one of the wires had unplug itself from the plug . So that said, the car is running like a charm. Tks to all of your comments and suggestions.
As they say across the pond---"Sorted"
Lou
Basque1
Old 07-31-2014, 07:28 AM
Clois Harlan's Avatar
Hey Lou,
The other ground wire that you found on your coil goes to your tachometer I believe. Also, when you have some time check all your header connections to see if they are tight, just for grins. At some point these will work loose and possibly cause a backfire (usually on deceleration). Both Ricks, Tommy and others are right about backfires they are different depending on whether they are electrical or mechanical.
Hope you are have some fun in your Cobra now that you have things sorted out.
Clois
"Let's roll"
"Be part of Something Good
Old 08-01-2014, 03:39 AM
BAsque1's Avatar
Originally Posted by Clois Harlan View Post
Hey Lou,
Clois
Clois:
Tks I do know about this, mine were recently installed and they are tight just after recent ceramic jet coating.
Lou
Basque1
Old 08-01-2014, 05:04 AM
Hey Lou,
Clois
When using an MSD ignition, the tach wire comes from the MSD box and not the coil. The coil should only have a black and orange wire connection from the MSD box.
Old 08-02-2014, 04:35 AM
BAsque1's Avatar
Yup taken care of it Tks
Lou
Basque1
