Old 11-04-2014, 06:20 AM
MOTORHEAD's Avatar
Default Tire dressing
Have been using a tire dressing to keep the tires looking new (low sheen, not shiney ) but recently I've noticed a brownish coating on them that does not come off easily, but it will come off if I rub it with my finger or a cloth, but in ribbed or lettering areas it is difficult to remove. I'm thinking it must be the tire dressing causing this (yellowing) .
Don't know the chemical make-up of what I'm using, but must be silicone or ???.
Anybody have similar experience with this problem?
If not, what are you using that doesn't give you any problems?
I'll post some pics later.
"When Injustice becomes Law,
Old 11-04-2014, 07:19 AM
This happens with EVERY type of dressing I've tried, and I've tried all the good boutique stuff, too. My solution: No More Tire Dressing. If you can start with fresh tires and never apply dressing you will never get that leeching white or brown stuff. Just keep them clean with an occasional scrub with simple green or other degreaser. They will stay black and not shiny. Best of all, no ugly leeching out.
If you already have several applications of layered dressings from over the years you will have to repeatedly scrub and degrease them over several lashings over time. It is not easy, so the best solution is to never apply that stuff in the first place.
Old 11-04-2014, 08:09 AM
DanEC's Avatar
My theory is that it's a nautral build up of oxidation and road grime that accumulates and needs to be cleaned off periodically to get back down to clean rubber. I'm sure I'm not alone in giving my tires a quick wipe with a sponge and soapy water when washing the car and then applying more dressing over the top of what the quick swipe with a sponge left on the tire. What has always worked good for me for cleaning tires is 409and a brush, but need to be careful about getting it off of paint and wheel surfaces pretty quickly.
ERA 782 Running
Old 11-04-2014, 08:44 AM
CHANMADD's Avatar
Purple power diluted or full strength in a spray bottle......just spray the whole wheel and wash with a hose and brush. I don't use any dressing and just keep the tyres clean......they still shine..
Old 11-04-2014, 09:48 AM
Bernica's Avatar
Senior CC Premier Member
Griot's makes a good rubber prep that strips and cleans pretty well. They also have several tire dressings...
Rubber Prep, 16 Ounces - Griot's Garage
Old 11-04-2014, 10:53 AM
MOTORHEAD's Avatar
Now that I think about it, when I use the tire cleaner on my other vehicles, (Bleach white, I think) the white foam spray changes to a brownish color as soon as it hits the rubber, so maybe the same reaction takes place with the dressing but takes longer? I haven't tried a tire cleaner on the Cobra tires as I don't like getting them wet (see rust starting between wheel and hub when wheel is removed) but I'll try it to see if it removes whatever is on the tire. If that doesn't work, I'll try the previously suggested cleaners.
Old 11-04-2014, 11:36 AM
Rick Parker's Avatar
Some of these tire dressings can damage paint, be careful..........
Old 11-04-2014, 11:53 AM
avanti-176's Avatar
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
This is the best stuff I have found. Cleans, protects and gives them that "new" look, not the "shiny wet look".....
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old 11-04-2014, 03:44 PM
MOTORHEAD's Avatar
Oh yeah, I bought some of that (303)many years ago. Haven't seen it since, thought they went under. I'll see if i can find some.
Old 11-04-2014, 04:16 PM
joyridin''s Avatar
I had that on my tires also. It is the UV protection in the tire coming tot he top of the rubber. Some cleaners and "protectants" make it a lot worse. The more you use, the tougher it becomes to remove it.
I bought tire cleaner and scrubbed the heck out of them. You cannot get real strong stuff or again, it will continue to pull the UV protectant out. I use Chemical Guys. It has been on the tire for almost 2 years now and you can just rinse the dirt off and the tires look like new.
[ame="http://www.amazon.com/Chemical-Guys-TVD_109_16-Sprayable-Dressing/dp/B001TI1F5Q/ref=sr_1_4?ie=UTF8&qid=1415146488&sr=8-4&keywords=chemical+guys+tire"]Amazon.com: Chemical Guys TVD_109_16 - Silk Shine Sprayable Dressing (16 oz): Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41RyAsm2fqL.@@AMEPARAM@@41RyAsm2fqL[/ame]
Old 11-04-2014, 07:48 PM
Rjw289's Avatar
Cobra Make, Engine: Contemporary Classic 289 FIA
Default Tire Dressing
I have tried many types over the years with mixed results. I have been using the Griots Tire and Rubber product for a couple of years now. It is not greasy, not too shiny, and does not come off onto the paint behind the tires.
Old 11-04-2014, 08:37 PM
Got the Bug's Avatar
Vinylex by Lexol also does a good job.
Doug
Old 11-05-2014, 04:26 AM
mdross1's Avatar
Been using this "Aerospace 303" product for years it leaves the rubber looking natural and it has a sun blocker. Great for vehicles that sit in the sun all the time. It is the only product recommended for camper rubber roves.
The best prep ( I have found) is Griot's "Rubber Cleaner" it cleans the rubber back to original with very little effort.
Old 11-05-2014, 06:07 AM
G-Pete's Avatar
Shoe shine (can) works for me the last 40 years...
DRB GT40 MK1 red #49- sold
SPF 2063
Old 11-05-2014, 06:10 AM
G-Pete's Avatar
BTW: this is the best for the paint job...
SPF 2063
Old 11-05-2014, 10:00 AM
Cobra Make, Engine: NAF 427
Aerospace 303 for me. And I buy in bulk on amazon (and Mothers Showtime Detailer) at half to a third the price of the auto store prices.
Greg
Old 11-05-2014, 10:52 AM
Adams polishes tire dressing works for me
Old 11-05-2014, 02:05 PM
Mastiff107's Avatar
Cobra Make, Engine: '66 Shell Valley, Original "K" Code 289
Ultima Tire and Trim Guard Plus is great also Lanes Super Blue Tire Gloss. Both satin finish and last for months.
Old 11-06-2014, 03:45 PM
Cobra Make, Engine: shell valley cobra-350 chevy
Will that Aerospace 303 make the "brown" letters white again? I made the mistake of spraying Sparkle window cleaner on my tires to clean them and the black turned white.
Put some wizard tire stuff on them and got the black back but have been afraid to put anything else on them and now the white letters are disgusting. They are Eagle GT2's.
Thanks, Russ
Old 11-06-2014, 03:48 PM
Thanks, Russ
