| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
05-24-2015, 09:22 AM
Cobra Make, Engine: Superformance, Roush 402R
Oil Pan Gasket Torque?
What would be the torque for the oil pan gasket bolts on my Roush 402R? Thx
05-24-2015, 11:25 AM
TX
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Not sure whether Roush is any different, but the Windsor blocks use 9-11 ft-lb on the four corners (larger bolts nearest the timing cover and the rear main cap), and 7-9 ft-lb on all the others.
05-24-2015, 11:56 AM
I suggest to tighten them down gradually, going around a handful of times.
I always watch the gasket and stop when it gets visually deformed a bit.
Are we talking about a cork gasket?
If I don't respond anymore, that's because I can't log in
05-24-2015, 01:36 PM
Zacttly how I do it and I use a 1/4 drive rachet, as soon as you see the cork gasket "squishing out a little" quit........I tighten the bolts a little at a time,usually 3 or 4 times,gggggggggggggooooooooooooooo ssssssssssllllllllllllllllloooooooooooowwwwwwwwww. ...
David
DAVID GAGNARD
05-24-2015, 02:25 PM
Senior CC Premier Member
CA
David
Crushing is good for grapes, not so good for gaskets. Everytihing David said above. Also, do a search on this site. Plenty of info here on pan gaskets and sealers.
05-24-2015, 03:57 PM
AZ
1/4" ratchet, two fingers and a thumb. No Squshy!
Karlos
05-24-2015, 04:32 PM
Windsor blocks oil pan bolts torque:
Side bolts 110-144 in-lbs, Corner bolts 144-216 in-lbs.
